Old 10-15-2009, 07:36 AM
yepingapple is on a distinguished road
Wink PMC force signal
Dear all,
Can you tell me how to force X/Y/D signal of PMC (FANUC 0i-TC system ) ?
I press PMC - PMCDGN -state, and select the signal, then press On or off, but don't ge the result .
Can you tell me why ?
Thanks for all support !
Old 10-16-2009, 06:21 AM
fomaz is on a distinguished road
I belive that you can use the Fanuc Ladder III software connected to your machine and change the ladder states/signals "online" with the machine.
I never did it, so I can be mistaken !
Filipe
Old 10-18-2009, 09:44 AM
yours_prabhat is on a distinguished road
TO force an input or output you need to ladder force enable first , what is the software version you are using , at the moment you will switch on the machine you will see fanuc Oi Tc and a version of software like RA .... please mention so I can help you Regards prabhatmishra@mail.com
Old 10-21-2009, 12:50 AM
wujp is on a distinguished road
you need to enter the PMC setting screen,make the IO Force enable.
don't worry,it's easy .
Tags
god
Pre-Loading force semo Linear and Rotary Motion 1 03-27-2009 09:39 PM
Drawbar force (MT3 & R8) The Blight General Metal Working Machines 2 02-14-2009 11:46 PM
Need to know how much force in psi RedDog22 Mechanical Calculations/Engineering Design 17 01-05-2008 04:32 PM
How much force on a cutter ? vroemm Mechanical Calculations/Engineering Design 4 06-14-2006 02:04 PM
Air cylinders, PSI & Force they have ??? Chris D Mechanical Calculations/Engineering Design 27 04-30-2006 11:23 PM
