Old 10-13-2009, 03:28 PM
cinci5 is on a distinguished road
18T parameter question
trying to set x axis backlash parameter but machine says locked out key is ok can't remember what to push to modify parameter
Old 10-13-2009, 04:08 PM
underthetire is on a distinguished road
PWE
MDI, offset/setting, PWE set to 1.
Old 10-13-2009, 06:11 PM
Is that lock/unlock funtion meaning (1) to unlock, (0) to lock again. I know you have to shut machine off to read change but want to lock it back out after making change.
Old 10-13-2009, 09:13 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
PWE = Parameter Write Enable
1 = Enable
0 = Disable
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 10-14-2009, 04:39 AM
ok thanks thats like the Haas I used to run
Old 10-14-2009, 12:04 PM
pwe
No need to cycle the power on a 18.
Old 10-14-2009, 02:54 PM
really, ok thought it was like the registry of windows it would read the backlash on bootup
Old 10-14-2009, 08:16 PM
muddobber76 is on a distinguished road
Late model Fanucs like 18i, 21i, will alert you as to what parameter changes require power shut down and reboot. In fact, these parameter addresses will not allow you to do anything else until you power off and reboot.
Old 10-15-2009, 04:33 AM
great thanks for all the help.
spindle rpm parameter question Daniel Wilcox LinuxCNC (formerly EMC2) 4 06-04-2009 12:04 AM
Fanuc 18T program/parameter question mikeyson Parametric Programing 2 10-06-2008 12:30 PM
Parameter (I think) question. g-codeguy Hardinge Lathes 4 05-18-2008 02:06 PM
Fanuc O-M Parameter question caddyshack Fanuc 1 04-22-2008 08:00 AM
Parameter question for MSX-501 on Mori mill tminnig Fanuc 0 10-02-2007 01:57 PM
