We have a Takisawa TC3 and just bought a Victor Vturn 20 with both a 1990 0TC. They both have the same Fanuc 5.9 NM servo motor and the weight of the turrets are comparable. There is no friction or any other mechanical problem, they both have very few backlash in the spindles or guides. The machines are both in very good mechanical state. The Takisawa is much stiffer on the X controll loop and is much faster when positioning a couple of hundreds of a mm. It moves instantly with the handle. The Victor is less stiff and slow when for example moving a couple of hundreds of a mm on the handwheel. After the position is done, you sometimes see that it moves a little more again after half second or so. I checked and optimized the backlash compensation (parameter 535) on the X-ax and it is only 0.011 mm which is good. I have the impression that the position loop gain is too low or it could also be that there is some integral gain that is not wright. We have some experience with adjusting PID filters on servo systems but I cannot find anything usefull in the manual. I only found a 8000 parameter that adjust the inertia ratio between the servo motor and the driven parts but I wonder if that could be the cause. I also found a general proportional gain parameter, but as it is only the X-ax I think it is tricky to change that. I have red the fanuc service manual but I could not find anything to start with. I think it is has something to do with the positioning loop filter. Is there a kind of service manual for adjusting the servo loop? I hope someone can help me a little bit. Thanks for your help Richard Last edited by richardfp4; 10-09-2009 at 02:42 PM. |
| Fanuc 18T positioning | bigalow | Fanuc | 0 | 11-06-2007 09:10 PM |
| 18i c-axes positioning | bigalow | Fanuc | 0 | 11-06-2007 08:57 PM |
| DRO positioning is Wrong.How to fix? | GisMo | Machines running Mach Software | 5 | 10-15-2006 07:20 AM |
| Fanuc O-M positioning | 723 | General Metal Working Machines | 8 | 07-30-2004 08:09 PM |
| photomicroprocessors for positioning | turmite | General Electronics Discussion | 0 | 06-24-2004 11:37 AM |
