Old 10-08-2009, 09:06 AM
sawdaddy2003 is on a distinguished road
how do i check my encoder cables
this is on a robodrill with a fanuc 16i-m control
Old 10-08-2009, 09:07 AM
Al_The_Man's Avatar
Resistance check end to end?
Old 10-10-2009, 07:28 PM
John_B is on a distinguished road
Make sure to check the cables with the table at different places in the travel. I have 4 different year Robodrills (this includes a pre-Robo model Tape Drill) and each has had the cable develop a break due to the repeated flexing into a tight radius under the table. I think the cable they used wasn't the high-flex specific type, probably just normal signal cable.
After the 2nd machine appeared with the symptoms of the encoder signal disconnect, I bought a 150' roll of the high flex - high dollar cable and just replaced it on the 3rd and 4th machine the minute the problems started to appear. Saved me alot of headache and time I wasted on the other 2 troubleshooting and thinking I had the problem, then it reappeared - back and forth, back and forth.
Need Help!- cables MR MOTION General CNC (Mill and Lathe) Control Software (NC) 0 07-24-2009 06:11 AM
Stiff Servo/encoder cables how to make more flexiable wcarrothers1 Bridgeport and Hardinge Mills 9 06-06-2008 08:11 AM
Encoder Cables JavaDog General Electronics Discussion 16 09-11-2007 03:51 AM
how to check encoder amps gv71 Gecko Drives 2 10-03-2005 05:00 PM
Cables itsme General Electronics Discussion 3 05-22-2005 02:35 PM
