Door interlock ?
Can you move the axis by hand ?
Now that i have set the parameter 1815 for x and z to 1, The machine will not jog i have no alarms Fanuc 16i-m on robodrill
Door interlock ?
no i can not move the machine in handwheel in any increment
ok it jogs when it wants to it seems fades in and out any sugg on that? and how do i set my machine so X,Y, can go to machine (0) with out overtraveling?
Parameter 1320 is the + overtravel limit amount. If you've changed 1815 you'll probably need to change 1320 to 9999999 so you can zero return. Don't forget to change it back to the original value after you're done.
