Old 10-02-2009, 12:49 PM
fomaz is on a distinguished road
Change language of 21i-m
Hello to all.
I have bought an used unpowered machine with fanuc 21i-m. The controller powers on, and some errors appear related to the battery power down (error nº 300). I have replaced the batterys and I am looking for a procedure to reset the axis to the correct position.
But before that I need to change the language of the controller. Currently it is in Spanish and I would like to have it in English. I must confess that I do not have experience with this controller, so be kind on explanations.
I have found the parameter to change languages, and when I try to replace the bit from 1 to 0 I receive a flashing error, that PROBABLY says in spanish protected. I have put PWE=1 before, so I really do not know what to do more.
Thank you
Old 10-02-2009, 03:58 PM
dcoupar's Avatar
#3102 = all 0's (bit 6 = 1 for Spanish)
#3119 bit 1 = 0
#3190 bit 3 = 0
Name:	21iM Language Parameters.jpg‎
Old 10-03-2009, 01:14 AM
Thank you dcoupar;
it is done! I will try now to solve the battery replacement.
Need Help!- Mo Language change greenery_fr Mazak, Mitsubishi, Mazatrol 4 05-29-2009 06:15 AM
language change on meldas 65-M scale Mazak, Mitsubishi, Mazatrol 0 12-23-2008 03:22 AM
Change language in Hypermill ltech2020 Hypermill 0 08-06-2008 09:29 PM
Need Help!- Language change on Mazatrol Cam T2 andreypav Mazak, Mitsubishi, Mazatrol 1 02-13-2008 08:23 PM
