Old 10-02-2009, 12:29 PM
cncwhiz is on a distinguished road
fanuc 3000
Can someone send me a sample program from a 3000 fanuc controller. It looks like a program for a 6m will work but the feed rates seem different?
Old 11-06-2009, 12:24 PM
706jim is on a distinguished road
You won't be able to use decimals in any of the addresses. Feed 50.0in/min would be F5000 (or similar).
Old 11-09-2009, 11:18 AM
How do I send and recieve to the control? It has a btr hooked to a pc. There is a running program in the machine but it is nothing I want. How do I drip feed?
Old 11-10-2009, 04:38 PM
I think that I will be able to get the btr issue. It does not seem like the spindle turns on by the program and I will need to use cutter comp? Do the 3000c have macro or is that asking to much?
Old 11-14-2009, 02:44 PM
renato13 is on a distinguished road
Hi.
I have two machine with Fanuc 3000c controls. I use PAC 3 program to communicate DNC through the LPT port (in DOS mode) Programmable in 1 /100 millimeters. Punctuation is not used! 1mm=100 , 10mm=1000 The program looks like:
G92X0Y0Z0
M35
G4P100
/ M41
/ M11
/ M3
G0G90G40G17X-46190Y-42000M58
GOG43H33Z4500
G1G91G41D2X-1F3000
G1Z-2000
G1X-1700F2000
G3G91X-300Y-4000I19853J-3500F2000
G1G91X50Y-10000
G3X300Y-4000I20153J-499
G0X5000
G0X-5000
G2X-300Y4000I19853J3500
G1G91X-50Y10000
G2G91X300Y4000I20153J499F2000
G1G91X1700F2000
G1Z2000
G1G40X1
G0G90G49Z0M36
G0G90Y0M51
G0G90X0M5
M2
Send me a PM exactly what you want. I send him my friend that it translated into my language.
Sorry for my bad English.
Best regards.
Old 11-16-2009, 11:34 AM
I figured out what is wrong with the machine. the "Y" axis is 10 times off the other axis. If I move X or Z, in tenths, in moves in tenths. If I move "Y" in tenths it moves in thousands. The code works the same way. I need to talk to a fanuc person who can tell me how to changes the parameters to make the Y move correctly?
Old 11-16-2009, 02:56 PM
I will check tomorrow in manual which parameter provides a step motor in individual axis.
Old 11-16-2009, 04:08 PM
That would be great!
Old 11-17-2009, 01:38 PM
HI
Check you this 4 parameters; No 4 for X axis, No5 for Y, No 6 for Z, No 7 for 4TH or W (second z axis if you have two z axis)
Sorry for my bad english.
Need Help!- PROBLEM WITH FANUC 3000 C Dragonbikes Fanuc 7 09-21-2010 09:34 AM
PROBLEMA CON FANUC 3000 C Dragonbikes Spanish CNCzone 2 03-23-2010 06:09 PM
Need manuals for Kitamura T-20 w/Fanuc 3000. GPena Fanuc 0 02-22-2008 01:35 PM
Repositioning zero on a linear Fanuc 3/3000 servo AZDEN Fanuc 1 07-11-2007 08:49 PM
Have anyone Fanuc 2000/3000 maintance manual? Jonne Fanuc 0 04-19-2007 09:42 AM
