Old 10-02-2009, 09:21 AM
CHANDRU is on a distinguished road
changing the circuit board
Friends,
What precautions/folowups required while changing the main circuit board for a ac digital spindle drive.
The spare board is having different version no.
Thanks and Regards,
chandru
Old 10-02-2009, 12:23 PM
GPena is on a distinguished road
The precaution number one is the electrostatic, it could damage the ic's for sure; use an device to avoid this.
If the 12 numbers in the model are the same then the pcb is the same. The version is for small changes, but the operation is the same in PCB's.
Check the ROM if it is the case, must be the same version.
Good luck.
GP.
Old 10-05-2009, 10:37 AM
fanucman is on a distinguished road
just note all jumper connections on original board.. then make sure they are the same Part number.. if they are
remove ALL IC chips that are able to be removed and transfer them to the new board.. and you should be ok..
Circuit Board Repair Help kwmkoester General Metal Working Machines 2 05-08-2009 06:54 PM
Circuit board printing Tony611 General Electronics Discussion 1 12-18-2008 10:45 PM
Anyone have an X2 circuit board diagram? dang Benchtop Machines 2 10-07-2007 02:03 AM
circuit board router CNCadmin DIY-CNC Router Table Machines 2 11-27-2006 06:25 PM
circuit board router lgalla DIY-CNC Router Table Machines 2 11-19-2006 12:50 PM
