| The machine is a EDM ,the machine has a om-a control...the main board is a A16B-1010-0210...The power supply board A16B-1210-0660 Keeps blowing the 3.2 amp fuse....If I replace the fuse machine will come up for a couple of minutes then blow the 3.2 amp fuse on the main board power supply...thanks for your help... |
| The 3.2 amp fuse supplies 24v to the front panel and CRT, I/O I would pull the I/O board then turn on the control, the machine will not come up, wait a few minutes to see if the fuse blows. If it still blows disconnect Crt and try again, if it does not blow put I/O board back in with all connectors off (M1,M2,M18,M19,M20) Try turning on again, If fuse does not blow,try putting one connector back on at a time, until you find the connector that is causing the fuse to blow. Once you find the connector look at your electrical drawings to see what that connector supplies. |
| The sugestion on pulling the I/O board is a good one...and I did try that..Thats why I thought there was a big differance in the fuse type...I did get the mp fuses off ebay baybe it was really old .and ready to blow...The drawings I got for the machine are for a machine with a 6m my machine has a om-a so I am realy lost when it comes to tracking anything down . Wish I could find some drawings for a om-a control...thanks to everone for there help thanks...see you guys later.... |
| Makino 1210 Thru Spindle Air | BailableOdin | General Metal Working Machines | 2 | 06-04-2009 08:28 PM |
| Need Help!- A16B-1200 | bbqa01 | Fanuc | 1 | 04-12-2009 12:39 AM |
| Need Help!- Ikegai 1210 down | bigmikehall | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 10-29-2008 06:53 AM |
| Electrocraft Servo 0660-12-031 | bemfarmer | Servo Motors and Drives | 0 | 09-03-2006 05:11 PM |
| Mc 1210 | motomitch1 | CamSoft Products | 14 | 08-27-2006 06:19 PM |
