Hi All; I have a Milling machine with Fanuc 6MB electronics. I also have a Greco Minifile (the kind with a 3.5" floppy drive). I'd like to connect to the Fanuc to to Greco act as a BTR so I can run longer programs. Does anyone have a similar setup or know the cable specifications to go from the Greco to the Fanuc? Is is a straight through cable from the 50 pin on the Greco to the 50 pin on the Fanuc mainboard (where the tape reader sits)? Please let me know and Thanks! Erik |
| This site will give you all the info on the Fanuc 6 parameters and necessary cabling http://www.machinetoolhelp.com/Appli...nications.html ------------------------------------------------------------------------------------ This pdf shout show you the configuration of the minifile output port http://www.grecosystems.com/manuals/CNCMinifileOM.pdf page 14. Last edited by MysticMonkey; 09-23-2009 at 07:47 PM. Reason: speeling |
Thanks for your reply. I already have a serial cable hooked to the machine and use it to transfer programs to the bubble memory. My Fanuc 6MB only has 8k of memory so programs must be small. Unfortunately, the Fanuc 6MB won't drip feed through the serial port. To drip feed this machine you must connect directly to the 50 pin Tape Reader header and, 'fake out' the machine to think it's reading from an actual paper tape. There are BTR's available and Dan Fritz has some nice software for a PC and a 25 pin parallel port. However, I already have this old minifile that should work, I just don't know how to hook it up. I'm looking for the pinout from the 50 pin connector on the minfile to the 50 pin connector on the Fanuc. Thanks! |
| Looks like this it top secret highly classified information you might have to buy one from the manufacturer http://www.grecosystems.com/products/cables.html
__________________ *********************************************************** *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~* *********************************************************** *__________If you feel inclined to pay for the support you receive__________* *_______Please give to charity http://www.oxfam.org/en/getinvolved_______* *********************************************************** |
I contacted Greco and they quoted me $400 to tell me how to configure the machine and to provide a cable. I can understand charging for the cost of support but it doesn't seem it should cost that much to hook one machine I own to another machine I own. I'll keep looking. |
1 P1 2 P2 3 P3 4 P4 5 P5 6 P6 7 P7 8 P8 9 SP 10 *TER 11 RDT 12 *RWT 13 FDT 14 OPT 15 *RWDT 16 *CLT 17 *RVT 18*ALM 19 CLR 20*REEL 21 +5V 22 +5V 23 +24V 24 +24V 25 RMT B 1 0V 2 0V 3 0V 4 0V 5 0V 6 0V 7 0V 8 0V 9 0V 10 0V 11 0V 12 0V 13 0V 14 0V 15 0V 16 0V 17 0V 18 0V 19 0V 20 0V 21 0V 22 0V 23 0V 24 0V 25 Nc From PTR P1....P8 *REEL: with reels *TER : PTR error RDT :Ready Rewinding *RWT SP: Sprocket To PTR FDT : Feed forward *RVT: Reverse OPT : Operate *RWDT: Rewind *CLT: Clear PTR CLR :clear *ALM:Alarm RMT :remote FDT: Tape feed ( All B pins is 0v(ground)) Hope it will help |
It was just under $2000 and I had a tech do it. You could probably do it for less by installing yourself. It is quite a usefull machine with 512k. |
#11
| Try www.memex.ca I have one of there 512K Sram boards and it is really easy to install and use. They can also upgrade your Fanuc 6 software (as long as you have 6MB11) by sending you a new set of Eproms which will let the Fanuc 6 drip feed without needing any extra hardware!! It adds a key on the screen to change from RS232 memory load to serial drip feed. Expensive but less hardware to worry about!! John |
| GE Fanuc & FANUC proprietary posts | CNCadmin | Fanuc | 44 | 01-05-2012 08:54 AM |
| FANUC & GE FANUC Repairs | RRL | Product Announcements & Manufacturer News | 1 | 04-17-2011 11:50 AM |
| can fanuc ac digital servo amplifiers be run by a controller other than fanuc? | js412000 | Servo Motors and Drives | 5 | 03-09-2011 09:11 AM |
| Greco minifile | 94mustang | General Metal Working Machines | 1 | 04-26-2004 07:10 PM |
