Old 09-21-2009, 05:42 PM
idtkid's Avatar
idtkid is on a distinguished road
Where is the syntax error in this Fanuc code?
Bear with me, I am very new to using industrial machines so im sure my error is very obvious.
Pasted below is the beginning part of my ~2000 line program, upon trying to run this in single block mode I get a syntax error, can you spot it?
(RhinoCAM posted this code, my Fanuc 21m controller adds a semicolon character at the end of each line)
O0001
N0005G0 G91 Z0
N0010G0 G90 G17 G20 G40 G80 G90 G94 G64
N0015G0 G90 G54 X0 Y0
(2 1/2 Axis Facing)
N0020 T3 M6
N0025 M8
N0030 G90 G1 X-0.8875 Y0.6125 F200. S5000 M3
N0035 G90 G43 Z0.25 H0
N0040 Z-0.0625 F60.
N0045 Y2.75
N0050 X-0.8753 Y2.8744
N0055 X-0.839 Y2.994
N0060 X-0.7801 Y3.1042
N0065 X-0.7008 Y3.2008
N0070 X-0.6042 Y3.2801
N0075 X-0.494 Y3.339
N0080 X-0.3744 Y3.3753
N0085 X-0.25 Y3.3875
N0090 X3.25
Rockcliff PE/Aluminum Router > 4'x8' CNC Router/Plasma > Manual DRO/CNC X2 > 4 Axis Syil SX3 and an Emco PC Mill 125
Old 09-21-2009, 06:02 PM
dcoupar's Avatar
What is the alarm number?
Old 09-21-2009, 06:04 PM
dcoupar's Avatar
Could be the H0. I would guess it should be H3.
Old 09-21-2009, 06:05 PM
dcoupar's Avatar
I would also think you want N0005 to be G0 G91 G28 Z0 to take Z up to it's home position.
Old 09-21-2009, 06:19 PM
idtkid's Avatar
Error is: 9 N 0 SYNTAX ERROR (i have changed H0 to H3, what does this do?)
Old 09-21-2009, 06:43 PM
dpuch is on a distinguished road
G43 H# activates the tool length offset for tool # in this case tool 3
dcoupar's other comment looks like a good change as well.
Which line is it stopping on? You should be able to look at the line after the error pops up. If you have a problem with that, try using single block until you get the error. That should narrow it down greatly.
Edit: Doh, your second line is % that usually marks the beginning and end of a g-code file.
Old 09-21-2009, 06:47 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
EOB goes before the comment
Old 09-21-2009, 07:20 PM
kazikw is on a distinguished road
First what I see isunnormal lookig line NG90G43Z0.25HO
I think firs should be H value than Z value.
Tray this way NG90G43H3Z0.25
If not work let me know
Old 09-21-2009, 08:22 PM
Superman's Avatar
Superman is on a distinguished road
O0001
N0005G0 G91 Z0
The % is not part of NC language
it is used with communication software for start and end of transmission
This is the only source for the syntax error. It is to be the only code on #1 line ( some controls use it at the end of the filename string on the 1st line--Okuma's ) or deleted, it should also be the last character in the file
All other items mentioned will not cause the machine to not cycle start
Old 09-22-2009, 01:13 AM
Sorry to nitpick
But having % mid way through the program doesn't cause the Syntax error.
Not having the program number after the % at the beginning of the program will cause an error.
When the data is sent over RS232 it uses the O program number after the % to name it's self.
  #11   Ban this user!
Old 09-22-2009, 03:12 AM
sinha_nsit is on a distinguished road
H0 cancels the tool length compensation, like G49.
Like many others, I am not comfortable with % sign. Remove it and run the program in single block to find out where exactly it alarms out.
  #12   Ban this user!
Old 09-22-2009, 01:20 PM
Originally Posted by MysticMonkey View Post
Sorry to nitpick
Actually on our machines 15,16, 16i They all default to O0000 if there isn't a program number, but that may be a parameter option. Anyhow it's almost certain the % should not be there. A question is it there in the file, or somehow on the control? And again which line is it stopping on in single block.
Auto Tool Zero VBA Code gives Syntax Error kiltjim Mach Wizards, Macros, & Addons 2 02-02-2009 05:32 PM
Need Help!- Fanuc Error code Racecarengineer General CNC (Mill and Lathe) Control Software (NC) 1 06-12-2008 12:46 PM
Fanuc 10M Error Code WallStreet General CNC (Mill and Lathe) Control Software (NC) 1 10-12-2007 03:41 PM
Error code help on Fanuc digger1969 Fanuc 8 03-29-2007 04:38 AM
syntax error pyroracing85 G-Code Programing 9 01-27-2005 07:09 PM
