Old 09-19-2009, 06:58 AM
f32cpe is on a distinguished road
noisy servo fanuc 0m
I had to replace a servo on my Miyano. It seems to be working fine with the new servo but it is noisy. I believe it is because it is oscillating. I was told there might be some parameters to change to help this out. If that is the case could someone help me out with that. something about holding position versus accuracy?
Thank you
Mike
Old 09-19-2009, 09:57 AM
yours_prabhat is on a distinguished road
Check the input frequency on servo specify the servo details so any one can assist you properly
Old 09-19-2009, 12:37 PM
what is and how would I check the input frequency? what specifications on the servo are you looking for? it is a fanuc redcap A06B-0310-B033. I am not near the machine right now, but if I knew what information was needed I could make a list of information to get / things to try next time I go back to the machine.
Thank you again
Mike
Old 09-23-2009, 07:37 AM
Rich 72 is on a distinguished road
Does it make noise while moving? I've seen guys try to hide problems with the backlash settings and the servo ends up fighting itself to keep a position.
Old 09-23-2009, 07:16 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Please supply us with the Fanuc control model and the Motor model numbers
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Noisy mill Thorpydo Benchtop Machines 1 12-03-2008 07:09 PM
Noisy rack Robin Hewitt CNC Plasma and Waterjet Machines 7 10-10-2007 01:00 PM
Noisy EMC Spindle ? northwestfab Fadal 7 09-19-2007 08:56 PM
noisy x axis fadalman Fadal 6 12-11-2006 04:32 PM
