| Just got my EMCO up and running, it is operating Fanuc 21M. I have named my program 0001 and have followed the directions in the manual which concur with the steps listed hereHERE I get error 9011 NO FILES FOUND ! My file is on the C drive and I have tried .txt .nc .ncc and .tap file extensions Lastly, the system is setup for I/O drive C Is there any reason my files simply wont load? Thanks!
__________________ Rockcliff PE/Aluminum Router > 4'x8' CNC Router/Plasma > Manual DRO/CNC X2 > 4 Axis Syil SX3 and an Emco PC Mill 125 |
| 21M not 21iM, its a PC based system running a Fanuc 21 "overlay" so the program has been transfered over my LAN to the computer C drive
| I could be wrong but I think your mistaken about the control. The 21 isn't a pc with a fanuc overlay, it is fanuc hardware based on an intel x86 CPU. Fanuc has an ethernet solution (data server), basically a mini pc based FTP server that DNC's files to the control. Perhaps this is what you have? |
| It turns out He is correct his machine has a emulated Fanuc 21M overlay http://www.emco.co.uk/pdffiles/WinNC.pdf All they do is change the keypad to suit which control your emulating As for the Alarm 9011 I do not belive this is a Fanuc alarm but a MTB - NC - Alarm relating to the integrated HDD (which is not standard or option on a 21M) Fanuc controls do not use filenames also they must have a standard formatting which contains the file name at the top of the program Probably the best idea is to output a file first then copy how that one is formatted before uploading your random file Best is to contact your local EMCo dealership |
I saw the pdf sent by you in a different thread, regarding memory cards. It talks about "PCMCIA cards" and "compact flash memory cards" etc. These two are different. What is "PCMCIA compact flash memory card"? Is it same as the second type? |
| Originally, the card slot on the panel used PCMCIA Flash cards. These seem to be obsolete or at least hard to find. Most people now use Compact Flash memory cards in a PCMCIA to Compact Flash Adapter (see attached). I've had better luck with smaller capacity CF cards, but these, too seem to be getting hard to find. |
#10
| please mail me on prabhatmishra@mail.com i will sure help you to loading files with the machine please clearly indicate your machine name , control PCB details etc. |
#11
| you can follow the procedure like : Setting machine to read from ATA- SRAM or PC-card 1.With control power “OFF” insert the PC-card into the slot to the left of the LCD display. DO NOT FORCE IT, IT WILL ONLY GO ONE WAY. 2.Power up machine 3.Enable parameter write. 4.Set NC parameter #20 to 4. 5.Disable parameter write. 6.Power down machine and remove card. Load program from machine to ATA/SRAM/PC-card IF YOU MESS UP AT ANY TIME WITHIN THE PROCEDURE, PRESS RESET KEY AND START OVER 1.Select the EDIT Mode. 2.Select Head 1 or 2 If control has two sides. If single side skip this line 3.Press the “PROG”(program) Hard key. 4.Press “DIR” softkey 5.Press (OPRT) soft Key 6.Press the right arrow soft key. 7.Type O-9999 (For output of all programs, Note: don’t forget the minus sign between the O and numbers) or For single program output type O#### (Where #### equals the program number you wish to output) 8.Press the “Punch” Soft Key. 9.Watch for the .”OUTPUT” in corner of screen as you press the “EXEC” Soft Key. Beware the program last punched will be called up into the memory. 10.Make sure you call up the correct program you want to run in the machine IMMEDIATELY or you will crash the machine. Do not forget to call up both heads if it is a double sided control. 11.All programs are output in a single text file on the PC Card. Load program from ATA/SRAM/PC-card to machine. IF YOU SCREW UP AT ANY TIME WITHIN THE PROCEDURE PRESS RESET KEY AND START OVER Note: If you are going to load a backup file with all of the programs in one file, you may want to create a new text file and copy only the program you wish to restore. Make sure you also copy the start code and end code in the backup file. Usually % sign in beginning and end. 1.Select the EDIT Mode. 2.Select Head 1 or 2 If control has two sides. If single side skip this line 3.Press the “PROG”(program) Hard key. 4.Press “DIR” softkey 5.Press (OPRT) soft Key 6.Press the right arrow soft key. 7.Type O#### (Whatever the file name is that you wish to load into machine) 8.Press the “READ” Soft Key. 9.If program is read properly you will see the program called into memory. Beware the program last read is the program that will run if you hit cycle start. Make sure you call up the proper program to run or you will crash. 10.The program is now loaded in the machine. |
#12
| Emco PC Mill is only a Fanuc look alike if hads nofhing to doo with fanuc its only looks like fanuc. you kan download the manual et Emco's home page www.emco.at if eny trobel you can send my a messigs (I'am the teknichan for danish agent). Sory for my bad enlish |
| Need Help!- Bridgeport Series 1 Boss 5 PC file loading | Electricky | Bridgeport and Hardinge Mills | 1 | 08-06-2009 09:51 AM |
| CNC88HS file loading question | MBX5 | Fadal | 8 | 06-13-2009 08:20 PM |
| Need Help!- Loading programs in a Fanuc 10M | Chappyd | Fanuc | 5 | 11-10-2008 12:46 PM |
| Need Help!- File loading issue | life3970 | Milltronics | 4 | 08-21-2008 11:00 AM |
| Need Help!- Error loading program file from USB on VF2 Mill... | intoolerance | Haas Mills | 1 | 07-12-2008 05:30 PM |
