Old 09-18-2009, 03:07 PM
driftmaster is on a distinguished road
Fanuc tool lenght compensation??
Hello.
Machine is mori seiki sh 5000 with fanuc MSG 501.
Here's the deal, i wonder if this is possible...
Machine running 4 different jobs, some with same tools, different people programming of course.
In some of the programs lets say tool T23 needs tool lenght (H) added with 0.10 (mm) in next job it needs to be -0.10..and so on..( meaby in third job it needs to be 0.15...)
Needles to say, much hassle.
Ofcourse im aware i could have several H codes, but that could cause problems later on when running the program again.
So is there any extra code that could be used just in program that could give you possibility to alter the tool lenght?
Old 09-18-2009, 03:42 PM
ChattaMan is on a distinguished road
I've no idea what a Fanuc MSG 501 control is but on the controls I use, I would adjust the different tool lengths with the wear offset.
In the prog use G10.
In prog one...
G10 L11 P23 R0.1
In next prog...
G10 L11 P23 R-0.1
In next prog...
G10 L11 P23 R0.15
G10 = parameter setting
L11 = wear offset (on newer control use L13)
P23 = corresponding offset number
R0.1 = amount of wear adjustment.
beege's Avatar
beege is on a distinguished road
Used to be G45, G46, G47 and G48 would increase/decrease moves by an offset amount. Don't recall if it was usable in G41 or G42, though.
G45 - single increase
G46 - single decrease
G47 - double increase
G48 - double decrease
These were used in place of cutter compensation a long time ago.
Old 09-19-2009, 12:51 AM
dpuch is on a distinguished road
If you have custom macro A or B check your manual for macro variables in the 2000-3999 range, or 10001-19999 range. These allow just setting #2123=-0.1
This is the same as ChattaMan described, just a different way to code it.
Old 09-19-2009, 02:22 AM
dcoupar's Avatar
Why not set the tools to a common standard and use the G54, G55, G56, etc. Z offset?
Old 09-19-2009, 04:13 AM
In prog one...
G10 L11 P23 R0.1
In next prog...
G10 L11 P23 R-0.1
In next prog...
G10 L11 P23 R0.15
Hi.
Very good, exactly what i was looking for.
I will try this on monday and see if it works.
Thanks alot!
Old 09-19-2009, 05:06 PM
Originally Posted by driftmaster View Post
Hi.
Thanks alot!
ChattaMan;
I'd like to ask one more thing.
The line with "G10 L11 P23 R0.1"
Where should i place this?
Lets say line like this after tool change.
"G43 Z10 H23"
Do i put the "G10 L11 P23 R0.1" before or after, or where should it be placed to work?
Old 09-19-2009, 08:53 PM
beege's Avatar
Oh and I believe if you use G91 with the G10 thing, you adjust incrementally, and G90 replaces the value absolutely.
Old 09-21-2009, 12:46 PM
samu's Avatar
samu is on a distinguished road
ChattaMan;
"G43 Z10 H23"
you need to put the line G10 L11 P23 R0.1 before calling tool length compensation(G43 Hxx)
Old 09-21-2009, 12:53 PM
Yes before, But possibly you will need to inhibit the read ahead buffer as well. I think 4 lines are standard, and optionally it will read something like 15 lines.
Anyhow if you think it isn't working, look for a buffer inhibit G or M code in your manual and put that between the G10 line and the one with G43. It may be overly cautions for the G10, but definitely consider doing this if you use the Macro variable.
  #11   Ban this user!
Old 09-21-2009, 02:28 PM
psychomill is on a distinguished road
As Coupar mentions and points to.... Why bother?
Just set a tool length on the offset page and use work offsets (G54-G59) to control the zero point. No need to G10 anything....
It's just a part..... cutter still goes round and round....
  #12   Ban this user!
Old 09-21-2009, 03:07 PM
Not specific to this problem, but there are others that would solved via changing offset wear via code in the program.
It may be more than 1 tool per program, and not in the same direction and amount. Or radius offsets, differing cutting conditions could require different offsets between parts of features.
Another possibility is a rotary table. Fixture offsets often do not rotate with the part. So either offset the tool, or use several fixture offsets with translated axis values.
Fanuc 5T Tool Nose Compensation John3 Fanuc 1 07-15-2007 10:58 PM
tool lenght question jedioliver Visual Mill 7 09-22-2006 10:27 AM
Tool compensation bg_izio General CNC (Mill and Lathe) Control Software (NC) 3 05-03-2006 08:40 PM
Tool compensation bg_izio CamSoft Products 3 04-27-2006 10:43 AM
