Old 09-16-2009, 10:24 AM
Montabelli is on a distinguished road
pin out pulse coder A860-0360-v501
A860-0360-V501 it takes cable A860-0360-T201
I have acquired one of these motors to run a 4th axis. the brake releases , the motor seems to test ok, but the encoder is definitely wired differently than my other motors. and is wired differently than the pinouts I have found in the posts. If any one has the pinout, or can tell me how I might determine the wiring format for the encoder, I could sure use some help. thanks
Old 09-16-2009, 11:26 AM
Al_The_Man's Avatar
That is a 2000p/rev incremental encoder.
Is the insert # in the MS connector a 22-14 or 20-29?
Old 09-16-2009, 12:05 PM
20-29 is the # in the center of the connector
Old 09-16-2009, 12:23 PM
Al_The_Man's Avatar
This should show the connections you have for the 20-29.
Old 09-16-2009, 01:39 PM
Al, unfortunately the chart doesn't add up with my pin out (observed)
here is what I have with lead color nd connection to the inside wiring leads.
A gray P 8
B -
C -
D black P 10
E -
F violet P 7
G pink P 9
H -
J orange & pink P 14
K red & pink P 13
L blue P 6
M -
N orange P 3
P -
R brown & green P 12
S green P 5
T yellow P 4
pins 1 and 2 loop back inside the motor to a pair of white motors which I assume are to a heat sensor.
the motor is an A6/3000
A06B-0128-B175#7000
Thanks for your effort thus far
Old 09-16-2009, 01:59 PM
Al_The_Man's Avatar
I found info on the motor number, and they show absolute encoders for this model.
It is probably an Alpha series?
Old 09-16-2009, 02:24 PM
yes it is an alpha series, I guess I should have typed it out. I suppose this means I have to get a new encoder. I was planning on running it with a Granite Devices VSD XE so I wont have to have commutation from the encoder.
Old 09-16-2009, 03:00 PM
Al_The_Man's Avatar
You could look for another Fanuc encoder, I can't remember whether the encoder taper mount is the same as the differential.
I have converted some Fanuc's using a circular aluminum plate mounted using the 3 existing mounting holes, to attach the encoder to.
Then screwed a 8mm machined shaft extension using the existing 5mm centre hole. Misumi USA sell these machined rods in different sizes.
I have used the NOS through-hole encoders that Renco have listed on ebay.
Old 09-16-2009, 05:36 PM
fastfixcnc is on a distinguished road
You guys ever had problems with circular interprelation where it does not give a alarm but the x axis just seems to quit and then decides it needs to play catch up with y but never gives an alarm or error we have had this machine apart several time but have not had any success at the problem fanuc has charged us alot of money and they are still scraching there heads NEED HELP IF ANYONE KNOWS
Old 09-16-2009, 06:28 PM
Al_The_Man's Avatar
You did not say who the MTB is, what do they have to say?
  #11   Ban this user!
Old 09-17-2009, 12:17 AM
sinha_nsit is on a distinguished road
Al The Man must celebrate 10000+ posts!
  #12   Ban this user!
Old 09-17-2009, 12:26 AM
Is there a problem in "radius method" of circular interpolation also?
"Centre method" requires that the specified centre must lie on the perpendicular bisector of the line joining the start point to the end point. If not, the "error" is taken care by a linear motion along one of the axes, at the end of circular motion, to reach the specified end point, provided the error is smaller than a value specified in a paramater.
Pulse coder alarm stevo1 Fanuc 14 08-18-2010 01:18 PM
Serial pulse coder bigalow Fanuc 3 02-19-2009 09:28 AM
Fanuc pulse coder pinout? Jonne Servo Motors and Drives 2 09-19-2007 02:15 PM
Unfit Pulse Of Pulse Coder Alarm Crashmaster Machine Problems, Solutions , Wireless DNC, serial port 2 04-23-2007 09:55 AM
Fanuc Pulse Coder Derek.C Fanuc 2 01-03-2007 08:24 PM
