Hi All, We're contemplating putting our toes in the water regarding 5 axis (VMC). Our plan is:- Get a Chevalier VMC with a fanuc 18iMB5 control (I believe this is full 5 axis contouring, whereas 18i would be 3+2 positional???). Get either a Nikken 5XA130 or Kitagawa TT120 tilting table Mount the table onto a sub plate that can be slid onto the bed of the Chevalier when required (using dowels to locate). Slide off when not required. This way, we still have a VMC which is 100% compatible with our other machines and can do all our other work, rather than a 'specialised' 5 axis machine which cannot then machine something 18" square. So for us, this is the most flexible solution. So, question time... Does it matter if the 18i control is either fanuc package A or B? Does it matter if the drives are Alpha or Beta? What options are needed with the fanuc control (as in 5axis cutter dia offset comp, tool length comp, fixture/datum offset comp etc???) Regarding the Nikken/Kitagawa table, does it matter what make/model motors are used, or do they have to match (identical) the control Anything else (and I'm sure there's buckets) that I need to know/ask/spec As always, thanks for everyones time. Cheers, Terry |
Yes it matters what drives/motors on the table. Talk to the dealer for the rotary table. Thats the best way. BTW you could buy a Haas mill with a 4/5 axis haas unit that bolts right on. The nikken table alone would be half the cost of the mill with table. |
| Poor man's cad (Blender) | eternauta3k | General CAM Discussion | 14 | 12-10-2009 07:47 PM |
| Introducing my build - the ScrapHeap CNC machine (or 'The Poor Man's CNC') | HankMcSpank | DIY-CNC Router Table Machines | 7 | 04-03-2009 09:18 AM |
| 11x26 Poor Man's DRO | njwtech | Mini Lathe | 16 | 09-04-2008 05:09 PM |
| Poor man's T-Slot wannabe | wyldesyde007 | DIY-CNC Router Table Machines | 4 | 02-24-2008 05:57 PM |
| Poor Man's Cutter Table | vladdy | Plasma, EDM and other similar machine Project Log | 5 | 08-19-2007 01:48 AM |
