Old 09-11-2009, 10:11 AM
cooperjm is on a distinguished road
Fanuc 10T communications problem
We lost communications with our 10T. The com port on the PC that we DNC from went out so we could not send to any machine. Once this was resolved we still have one machine that will not receive programs. With this machine we have been able to punch to hyper terminal, so the transmit seems to be working.
Here are some things we have tried …
-Swap cables, cable is good, it will send programs to other machines
-checked parameters, went through and all looks good
-checked for broken wires on the DB25 at the machine, checks good
I am beginning to believe that the communications have fried on the main board. Searching over the net I have seen where the 1488 and 1489 chips go bad and can be replaced. Looking at the main board I have found several chips with 89 as the lat number but cannot find one with 88.
Does anyone know which chips on a 10T controller work the RS232. If so where are they located? Any other suggestions on troubleshooting or repairing this issue would be appreciated.
Old 09-11-2009, 04:06 PM
GPena is on a distinguished road
Check the connection from the RS232 port to the mother board, the chips goes connected to that connector in the mother board. Or let me know what main board you have, maybe I can help you.
GP.
Old 09-11-2009, 05:56 PM
JimBoyce is on a distinguished road
Check for SN75188N and SN75189AN chips. These are newer models.
Old 09-11-2009, 06:45 PM
Al_The_Man's Avatar
There is usually two RS232 ports on the 10, one on the main board and one at the operator panel.
If you send me a PM with an email address I can send the Fanuc RS232 manual.
Old 09-15-2009, 01:45 PM
Board Part number
The number on the main board is A16B-10-10-032. Please let me know where the communication chips are.
Thanks.
Old 09-16-2009, 04:45 PM
This sounds like our recent problem. Al The Man's and other posts were very helpful in solving the problem. We have a 10M in a Victor Mill. On the mother board the following chips were about 5" from the input connector, SN75188N and SN75189AN and next to each other, but were hidden under a "T" section. We got new chips and soldered them in and celebrated. Our machine had a blank connector in the control consol that possibly could be a second RS232, but it was a blank. We do not think there is a second RS232 on the machine. We looked very carefully.
Tags
10t, fanuc, mori seiki, rs232
Anyone have a communications problem before?? chipsahoy Fadal 12 11-05-2009 11:34 AM
I need help with communications peterpan3 Mazak, Mitsubishi, Mazatrol 6 03-24-2009 06:44 AM
Need Help!- Communications Problem: PC--> Bridgeport Model R2E3 (BOSS 8) rams_head Bridgeport and Hardinge Mills 0 03-04-2009 08:15 PM
Newbie- USB - RS232 Serial Communications with Fanuc CNC Controllers Robert Bird Controller & Computer Solutions 1 01-30-2009 05:04 AM
Mastercam Communications Problem DELL Mastercam 9 05-03-2006 11:28 AM
