Hi to all. I'am new here. I have a mori seiki mill mv-35/40 ser#287. I have a 401 alarm That comes go's. some times the mill will run weeks on ends. but the 401 will come up and it will not run at all. I can shut the mill dowen for a week or two and power back up and run for some time. I can look at the cards in the back of the cnc and i never see a alarm led on. Can anyone help? Thanks rmanning |
| Hi There; From some of my old notes on alarm 401 this is a servo alarm I think. Some of the things that could be going on is the incoming voltage or transformer tap settings. My note also state that the problem could be on the Velocity Control Circuit side of the drives. Also have a note that states that the incoming voltage at the drive could be at it max or below its minumum. Also you may try checking backlash of the trust bearings of the axis that the 401 alarm is on. Like I stated my notes are old , so not sure if any of this will be of help to you since alarm code may be different than I am using. Contact Fanuc USA . They do have some tech there that know the older controls . MTSS Service |
| hi 401 is ready signal of servo drive is turned off ! DRDY if red light up consider on and let us know , if no light up there is always poor contact inside servo amplifire or there is problme on servo PCB . please check and retiten all conection and use spray cleening for PCB you can nothing more to do if this problems appears by weeks |
| Control of cooling plate,3 cards have been exchanged for two machine .Alarm same HCAL. http://www.cnc-shopping.com Last edited by artest; 09-16-2009 at 07:43 AM. |
| Please mention the Model Number PCB and Drive Details If Posible Than Motor ID also So I can suggest Why the VRDY OFF signal is coming (I mean AL 401 ) for any further suggestion free to communicate me prabhatmishra@mail.com Regards Prabhat Mishra |
| SERVO ALARM 401 REPEATING IN MORI SEIKI | CHANDRU | Mori lathes | 5 | 12-02-2010 05:36 AM |
| Mori SH403 5136 alarm | JACKOFTRADES | Mori lathes | 3 | 08-30-2010 09:46 AM |
| Need Help!- Memory alarm on Mori seiki lathe | hectorbach | Mori lathes | 14 | 01-05-2010 06:04 PM |
| Mori sl-15 with a new code 100 p/s alarm | bob1112 | Fanuc | 8 | 07-09-2007 11:32 PM |
| Sl-3h mori w/ Fanuc 11t [alarm] | B_Bueno | Fanuc | 5 | 06-24-2006 04:34 PM |
