Old 09-08-2009, 06:48 AM
RFL RFL is offline
RFL is on a distinguished road
Help please. Fanuc O-T alarm 409, 414,424
The machine we have is a TongTai TNL 100-T with Fanuc O-T control.
When i turn the machine on i get the following alarms
409 servo alarm
414 servo x axis detect err
424 servo y axis detect err
on the spindle amp module it shows alarm code 30
any ideas?
Old 09-08-2009, 07:04 AM
MTSS Service is on a distinguished road
Check the fuses on all the controls. I believe you have small fuses on all the drives.
Also check all breakers and thermal relays. There could be a thermal relay or breaker that could be trip.
MTSS Service
Old 09-08-2009, 07:33 AM
RFL RFL is offline
everything looks good. The relays seem fine and the breakers are all reset.
We have had this problem before but after turning the machine off and on couple times it goes away. The machine was turned off for a week while we was on shut down last week and since then it wont get past this alarm
Old 09-08-2009, 04:05 PM
CNCRouterMan is on a distinguished road
Has same problem and found power supply board had burn marks. You need to pull the power supply board out and inspect it. You might find the problem there.
Fanuc 0 MC, 001 TH Alarm, while DNC DHYSTA Fanuc 6 10-21-2010 09:17 PM
fanuc 6m 421 alarm actionman General CNC (Mill and Lathe) Control Software (NC) 3 03-01-2010 01:19 AM
Fanuc PS/90 Alarm mattstawicki General Metalwork Discussion 7 10-21-2009 11:15 AM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
Fanuc 6T 607 PC alarm and more saltracer1 Fanuc 11 11-08-2007 01:11 PM
