Old 09-02-2009, 12:15 PM
microinv is on a distinguished road
Alarm 530 overtravel on Z and no movement
Guys,
This is my second post after I lost machine parameters in Wasino CM-3 with Fanuc OM controller. After I got the parameters from Wasino and put them back in. I was able to run the machine. However, it seem that the machine lost its home position. So, I was told to zero return all axis by cancel the software limit (press and hold 'P' & 'CAN' during opening up). I was able to zero return axis x and y. During zero returning of z, it seems to move up and pass the first limit switch which set the home position (I believe). Now I noticed that the Z axis hit the second limit switch and it stopped there. At this moment nothing can move. If I turn the 'mode' switch to other mode except 'O.T.Release', the machine show 'NOT READY ALARM' with 'Emergency Stop' light came out and I think all drives were off. When I turned mode switch to 'O.T.Release', monitor show 'ALARM' (instead of 'NOT READY ALARM'), the LED 'Start' flashed for a moment then gone and the LED 'Error' came out eventually. There were some sound of relay and contactor trying to start the drive at the back of the machine (I believe).
Anyway, I cannot jog or move any axis even in the position away from the limit switch. I look over the internet for any case like mine, but I couldn't find one. In most case, the machine still can be move. I review the parameters that I input, all seem to be correct according to the backup from Wasino.
If you have solution to this or any comment/suggestion, please help me out here, the machine has been stopped for several days now, and I really need it back.
Thank you,
Old 09-04-2009, 07:13 AM
udrııl79's Avatar
udrııl79 is on a distinguished road
you must check z axıs limıt swic. it s must be clean and dry. its cable is good. !
whıch control your Cnc machıne?
machıne is new or old !
we need some informations For help !!
KİNG NOTHİNG
Old 09-04-2009, 07:23 AM
stevo1 is on a distinguished road
Microinv,
I responed to this in your other thread. May want to check that one.
King,
It is a Fanuc Om cotrol. I didn't see a year.
Stevo
Old 09-05-2009, 09:33 AM
It's fixed
Guys,
Thank you for all your help, also everyone who came to visit my post, the machine is now back to normal. I am greatful to join this site.
Pao
Old 09-08-2009, 06:38 AM
What was the solution??
Stevo
Tags
alarm 530 fanuc om, overtravel alarm, wasino fanuc om
Need Help!- FANUC OT ALARM 520 OVERTRAVEL +Z berthagua Fanuc 7 12-20-2011 10:21 AM
alarm 510:overtravel X+ hell_pk Fanuc 8 12-02-2011 08:55 AM
Need Help!- Z + Overtravel alarm cd0426 Fanuc 3 11-21-2009 12:23 PM
Y hard overtravel alarm Chappyd Hyundai Kia machine 2 02-05-2009 07:25 AM
Keep getting z axis overtravel alarm 146 dragon864 Haas Mills 3 07-20-2007 06:13 PM
