Old 08-29-2009, 01:18 PM
teamjnz is on a distinguished road
unusable G code commanded
Hello,
I am having troubles... I have been CNC turning parts for years. I buy a used small CNC lathe, 1998 Femco with a Fanuc O-T control. I score a small first job. Now I try and run the machine for the first time and it doesn't like the canned cycles.
Please help... Could it be the a turned off parameter??
The alarm reads 010 P/S. My books says "unusable G code commanded" It bombs out when it reads the G71 line and the G76 line. I can work around the G71 rough cycle but I need to be able to thread the part.
Here is the code
(ROUGH OD PROFILE)
G00X1.Z.03
G71U.1R.015
**G71P1000Q1001U.01W.005F.007
N1000G00X.6794
G01Z-.0059F.02
X.784Z-.044
Z-.465
X.8072
G03X.8892Z-.506R.041
G01Z-.975
X.938
N1001X1.
G0Z1.
and the threading cycle too
(FINISH THREAD)
T0303
G97S1000M03
G00G99X1.Z.25M08
G0X.984Z.2
G76P011060Q0010R0010
**G76X.744Z-.4095R0P0200Q0047F.059
G00X.968Z.2577
G0Z1.
I am drowning please help
_____________
teamjnz
Old 08-30-2009, 03:20 AM
The Engine Guy's Avatar
The Engine Guy is on a distinguished road
Try using the "simple" G32 threading command in your Cad-CAM to produce the code, works on my lathes with OT.
Regards
Rob
Old 08-30-2009, 10:23 AM
dcoupar's Avatar
Just for grins you might want to check the TAPEF setting (see attached).
1=F10/F11 Format (Single line multiple repetitive cycles)
0=F0 Format (2-line multiple repetitive cycles)
Name:	0T TapeF Setting.jpg‎
Old 08-31-2009, 07:28 AM
stevo1 is on a distinguished road
PM sent.
Stevo
425 UNUSABLE G CODE 31!! guydrisc Okuma 19 06-01-2009 05:55 AM
Need Help!- Bridgeport EZTRAK Alarm: commanded X-axis move too far positive Pribbs Bridgeport and Hardinge Mills 4 01-23-2009 08:34 AM
Need Help!- Alarm: commanded X-axis move too far positive JonMatear Bridgeport and Hardinge Mills 3 08-06-2008 08:41 AM
parser: commanded z axis move to far possitive tonymann Bridgeport and Hardinge Mills 1 11-09-2007 11:05 PM
Now I get a "197 C-AXIS COMMANDED IN SPINDLE MODE" ALARM theemudracer Fanuc 14 01-07-2007 11:10 PM
