Old 08-28-2009, 03:05 AM
newckl is on a distinguished road
Fanuc 18i-TB Unlock hidden parameter
Hi all,
We got few Autolathe machines of Fanuc 18i-TB controller. Due to tight tolerance, our machines cannot achieve the accuracy we wanted. We performed the laser calibration on the X-axis but when we want to change the Pitch Error Parameter of the machine, we cannot find that particular function.
Normally, when we press buttons "Offset/Setting", "System", then "Right Screen" keys, we can see the function "Pitch" available at the bottom of screen. But however, for all our Autolathe we cannot see the "Pitch" function soft key. Anyone can help and unlock this function/parameter for us? For your info, we already unlocak the PWE to 1 prior to the above steps.
Thanks.
Regards
Kelvin
Local Precision Manufacturing.
Old 08-28-2009, 06:49 AM
stevo1 is on a distinguished road
Your pitch parameters are not located under the "settings" it is located under the "service".
You have to go to the "settings" as you stated to change the PWE bit but then have to go to the "service" to reach the pitch parameters.
Stevo
Old 08-28-2009, 08:40 AM
Re
Hi Stevo,
Thanks for the info...
I am not sure how to locate the "service" function. Is it the softkey at bottom row? Is it still pressing the button "offset/setting", "system" then it shown the "service" softkey?
Rgds
Old 08-28-2009, 09:11 AM
My bad I apologize it is not the “service” key on the 18’s, it is on my 15’s . It is the “system” hard key then press “parameter” softkey. This will be your system parameters that you should be able to just type the parameter number for the pitch and then press the “NO.search” softkey. I believe that you can also get the pitch by “system” overarrow then “pitch” softkey.
Stevo
Need Help!- unlock code for BOSCH CNC CC220 JuanMatus General Metal Working Machines 7 02-19-2012 05:13 PM
How to unlock/change password on Bandit VI controller supermax General CNC (Mill and Lathe) Control Software (NC) 6 01-24-2011 06:44 PM
Need Help!- Okuma OSP 500 Unlock the pitch parameter. newckl Okuma 0 12-30-2008 09:46 AM
Unlock a post to modify svx-ff Post Processors for MC 5 07-11-2007 05:59 AM
18i hidden parameter view/change? john k Fanuc 6 12-22-2006 12:58 AM
