Old 08-25-2009, 05:57 PM
domax is on a distinguished road
Unhappy TUE 15 Vertical cnc Fanuc 18T
Hello every brothers .
I'm a new in the machinist , I need the forum or website
for this machine (vertical cnc Fanuc 18T) or N# 015-702
but I' ve the problem for set-up in offset and measure
the tools . Thanx advance for someone can help me to
fix out .
Thanx again .
domax
Old 08-25-2009, 09:17 PM
fanucman is on a distinguished road
whats the problem?
Old 08-26-2009, 03:11 PM
Hey brother Fanucman .\
But I needs the process .How can I set-up in offset and measure
the part fix in the turn table this machine . I try take the measure by comparator guide , is that right ?
Could you show me some help . please
Thanx
Old 08-27-2009, 04:27 AM
sinha_nsit is on a distinguished road
How to enter the offset distances into the offset tables
On a machine with Fanuc control, the following procedure can be adopted:
• Select the tool for which offset setting is to be done, by pressing the tool change button on the machine operator’s panel, required number of times. Alternatively, execute the appropriate T code (say, T0100 on a lathe, or M06 T01 on a milling machine) in the MDI mode.
• Bring this tool to a known axis position (say, X = 10) manually, using continuous feed (JOG mode), incremental feed (INC mode) or handle feed (HANDLE mode), as appropriate/convenient. For accuracy in positioning, it is recommended to use successively small increments (say, 0.1 mm, then 0.01 mm, followed by 0.001 mm), as the tool approaches the desired position. Continuous feed should be used only for quickly bringing the tool near this position, initially. To judge whether the tool has actually touched the surface, turn the spindle manually and look for a tool mark on the surface. Another method involves inserting and continuously shaking a thin piece of paper between the tool and the workpiece, while the tool is made to approach the workpiece. The moment the paper gets stuck, the tool can be considered to have touched the surface. While inputting the values in the offset tables, allowance for the thickness of the paper can be taken, if felt necessary.
• Press OFS/SET key on the MDI panel. OFFSET, SETING, WORK and OPRT soft keys will appear. Pressing OFFSET soft key will display WEAR, GEOM and OPRT soft keys.
• For setting work offsets, press the WORK soft key. If it is already highlighted, i.e., selected by default, there is no need to press it again. On work offset screen, bring the cursor to any of the coordinate displays of G54 or G55 or G56 etc., whichever is currently active. If the workpiece coordinate system to be edited is other than G54, then the corresponding G code (say, G58), must have been previously executed in the MDI mode, to make it current. The currently active workpiece coordinate system is displayed at the top-left corner of the work offset screen.
• For setting geometry or wear offsets, press OFFSET soft key followed by GEOM or WEAR soft key. On geometry or wear offset screen bring the cursor to the appropriate row number (offset number), say, row number 2 for tool number 2, under any column.
• Type X10 (for this example) and press MEASUR soft key. This will make the correct entry of the X-offset value. In a similar manner, carry out the offset setting for the other axes also.
Is this what you wanted to know?
Go-Well vertical mill Matt130 Benchtop Machines 0 08-14-2008 02:09 PM
HELP WITH VERTICAL CENTER BRIDGEPORT BPC-250V, FANUC 11M, 1986 MACHINNE darioespin Fanuc 4 08-05-2008 10:03 PM
Vertical Integration Celling It General Metal Working Machines 5 01-23-2008 09:30 PM
where to buy these vertical clamps? slow_rider General Metal Working Machines 4 10-11-2006 07:22 PM
Best Vertical Mill? bvandenb Haas Mills 11 04-20-2005 05:47 AM
