Old 08-25-2009, 12:29 PM
John_B is on a distinguished road
Schematic detail needed...
Does anyone have a schematic for A06B-6059-H003 AC Spindle Servo Unit, the spindle motor amp?
My previous regen resistor overheat problem was fixed but has returned exactly as before and I would really like to find the component that is failing to help troubleshoot and narrow the cause.
I can't get this info from the shop that repaired it previously unfortunately.
Old 08-26-2009, 12:23 PM
Nobody???
Any thoughts?
Old 08-26-2009, 05:15 PM
fanucman is on a distinguished road
are you getting a Discharge alarm?
Old 08-26-2009, 07:15 PM
No. 2003 "Resistor Unit Overheat" is the alarm, same as last time. The resistors are sinking current from the moment I start the machine - with the spindle running or not. The fans can keep them cool for about 15 minutes before it trips.
I sent it out for repair early this year, got it back and it worked until Monday.
Old 08-26-2009, 09:40 PM
whats the 3 phase power looking like coming into the drive? should be 220 and balanced between all 3 phases..
Old 08-27-2009, 12:02 AM
wizbangdoodle is on a distinguished road
Could be the transistor/diode pack that controls when voltage is dumped across that resistor. Some repair shops don't check that thoroughly. They just run it a few minutes and call it good.
Old 08-27-2009, 10:45 AM
fanucman - I'm getting 238 on each, balanced real well though.
wizbang - Could be, the shop I sent it too won't comment - just that they repaired it. Pi**es me off too, I've been using these guys for almost 10 years - I think it's pretty obvious I'm not out to argue with them. I just don't want to fight this over and over and over.
Old 08-27-2009, 02:58 PM
that is too high... you might want to lower that somehow...
Old 08-30-2009, 05:58 PM
I've got a buk/boost transformer in mind I'll pick up Monday and install that to see what effect it has.
Old 08-30-2009, 08:14 PM
jdeere4250 is on a distinguished road
What alarm on the drive unit?? I have the details. But better to Diagnose accurately first then Plan of action.
  #11   Ban this user!
Old 09-06-2009, 02:27 PM
Sorry about the delay - wife had to go into hospital & I wasn't at the shop for a couple of days and then had to catch up when I did get back.
The drive unit doesn't show an alarm - just the operator control display. I bought a buck boost transformer as I mentioned and hope to get it hooked up in the next few days to see if the corrected power input helps the issue.
Rgds,
JohnB
  #12   Ban this user!
Old 09-06-2009, 03:39 PM
Again, I have the necessary info.
But I think it is not your fanuc sp. drive unit.
What Make and model of Machine, which make , model control?
And what/what axes does this machine tool have?
Generally there is no external resistor for fanuc sp. drive unit.
There are ext. resistor unit, for fanuc servo drive units.
I think this may be caused by axes units not Sp. drive unit.
I hope your wife is better.
Need Help!- Fanuc OM-PMC to PC cable detail dinesh Fanuc 5 10-29-2010 11:17 PM
MasterCam Art X Detail stevec Mastercam 0 01-28-2009 10:10 AM
Option detail of Fanuc 11t rajesh_1355 Fanuc 1 02-17-2007 09:12 AM
A question of detail dherbman DIY-CNC Router Table Machines 4 03-03-2004 03:34 PM
