What is the point of diagnosis data / codes? Are they there for the owner/ operator or the service guy who is more of a specialist. They must relate to something, is there supposed to be a list of them that you can refer to? Any advice would be helpful thankyou. Steven. |
| Thanks Bill, do these maintenance manuals have to be machine specific or are they for the controller only? I have been trying to find out more about the diagnosis process but not getting very far. If there is something wrong, would the item of data flash from 1 to 0 to let you know? |
| They are basically for the control, not OEM specific. They are a very usefull tool as the status, 0 or 1, of each bit with show the status of different machine fuctions. e.g. 0~639 I/O signals, 700~701 the current state of the NC, 712 cycle operation status. etc. The maintenance manual has the individual explanations. Al.
| Thanks Al, I have to try and find myself one of these manuals, some of my data are flashing back and forth as though a switch may be stuck midway. Anyone know if these manuals are available electronically or do I have to try and find the actual book? |
| I don't believe Fanuc put the 6 manual on PDF as they did with the later systems. Al.
| Thanks again Al, I guess I'm gonna be on a bit of a mission to come up with the manual. If anyone can guide me to which part of the machine these lines may refer to would be a great help. I will try and type it as it looks but with a "?" in the positions that are flashing. 0195 00?????1 0196 ????111? 0197 ?????1?? 0238 ???????? 0239 00?????? 0800 000? 0801 -000? The negative sign on line 801 is also flashing. I guess even if I could find a book it would have to be ordered in. If anyone could help out meanwhile, that would be fantastic. |
| 800 801 are servo error registers for X Z. Al.
#10
| Hi everybody, had some luck with the manual, got one on ebay. Might be a while till I see it but least I know it is coming. I am trying to get a service guy out to check the machine over for me as well. Hopefully all goes well. Steven. |
#11
| You also need the machine electrical schematics which originate from the MTB, not Fanuc. Al.
#12
| I think I already have that, a folder labeled wiring diagram about 3/4" thick full of old blueprint type drawings of all the electrical components on the machine. Lucky for me it came with it. Hopefully they will go well together. |
| Tags |
| diagnosis, diagnostics |
| G-Codes | mocnc | DIY-CNC Router Table Machines | 2 | 07-28-2008 07:36 AM |
| 417 & 427 codes | chetohead | General CNC (Mill and Lathe) Control Software (NC) | 0 | 04-30-2008 02:40 PM |
| Axis bypass procedure for diagnosis in 10M | ranjankrana | Fanuc | 4 | 12-25-2007 09:47 AM |
| M-codes and G-codes 4 Matsuura ES-1000V | maximusek | G-Code Programing | 2 | 11-27-2007 06:41 AM |
| g codes | AJFab | G-Code Programing | 1 | 05-19-2006 08:16 PM |
