Old 08-10-2009, 11:04 AM
jaimeeduardo is on a distinguished road
strippit cap 1000 with fanuc 0p control
Hi, i have a strippit cap 100 with the fanuc 0p control and only 2 servo motors (x and y), the turret has a normal 3 phases motor always running coupled to the turret with a pneumatical clutch. When i select the tool 3 it retract the turret pins (upper and lower) and engages the clutch to make it spin. When it stop it extend the upper and lower pin to lock the turret, the problem is that the pins are not always aligned with the turret and the cycle stop. Does anyone know if there is a parameter on the fanuc 0p to adjust the stopping time of every tool station or how the fanuc decides when to stop according to the tool?
Strippit Cap 1000 SGARCIAM General Metalwork Discussion 2 08-10-2011 08:52 AM
Problem- Bridgeport VMC 1000/22 GE Fanuc 18i-M DNC americad General CNC (Mill and Lathe) Control Software (NC) 2 05-01-2009 06:43 AM
Strippit Hecc 80/3 control help javajesus General Metal Working Machines 1 04-06-2009 01:06 PM
Looking for hardinge vcm 1000 with fanuc 0-md control maintenance manual samu Bridgeport and Hardinge Mills 5 09-02-2008 08:36 AM
Torch Height Control for PowerMax 1000 barnon Mach Plasma / Laser 2 08-11-2006 11:30 PM
