Old 08-10-2009, 08:40 AM
dinesh is on a distinguished road
Smile Fanuc 10T
We did purchased last week a used Moriseiki cnclathe. I installed it start working nicely.
But the problem know the feed rate is not changing by the G01 X...F.. command. what ever the F.. command the feed rate shows 200mm/min on screen.
We can be reduce by feed override switch when program is running.
Even we program F rate 0.05mm or 5000mm/min feed on display shows 200mm/min.
Please suggest which parameter ....? or any otherthings i need to look for...?
Thanks in advance.
Dinesh
Old 08-10-2009, 09:23 AM
stevo1 is on a distinguished road
So this was working before when changing the feedrate the display would change as well? Then it just stopped working?
Does the machine actually feed by the commanded feedrate regardless of the display? So if you program F.05 the machine displays 200 but is the machine feeding at .05 or 200?
Stevo
Old 08-10-2009, 08:11 PM
dcoupar's Avatar
Sounds like maybe DRY RUN switch is on?
Old 08-11-2009, 12:57 AM
sinha_nsit is on a distinguished road
To pinpoint the problem, execute one line G01 command without F-word. Does it alarm out? Insert G98 also.
Execute in MDI mode also.
Old 08-11-2009, 09:25 AM
thanks for the reply.
Yes, I tried with feed rate o.05 it moves physically 200mm/min and with any feed rate program also it moves with 200mm feed.
i will try G01 with G98 in MDI and check.
I checked dry run is not on. Dry run feed rate is fixed in parameter for 5000
thanks and any more suggestion ...?
dinesh
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
FANUC & GE FANUC Repairs RRL Product Announcements & Manufacturer News 1 04-17-2011 11:50 AM
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Fanuc & GE Fanuc Repairs RRL Product Announcements & Manufacturer News 0 10-01-2008 12:42 PM
