My 0i Mate TC has a male 9-pin RS232C connector. My computer also has the same connector. I wish to connect my computer to the CNC, only for the purpose of transferring part programs (i.e., not for drip-feed execution). I would like to know the following: 1. Is some DNC software or a similar software required even for my limited requirement? 2. How to prepare the cable and how are the pins numbered on the connector? 3. If no software is needed, what would be the procedure for program transfer? Thanks and with best regards. Sinha |
| Dear Mr. Sinha, you can used CIMCO or DNC4U Software for send & receive G code from PC To CNC machine. 25pin(CNC) 9pin(PC) 2 *--------------* 3 3 *--------------* 2 4 *--------------* 5 5 *--------------* 4 7 *--------------* 7 6*------ Tie pins 6, 8, and 20 together on CNC side 8*------ 20*----- J>NAYEBI |
| Sinha, I got your message. Are you sure that it is a 9pin on the CNC and not a 25pin? I will have to do some digging. I don't think that I have seen the 9pin on the CNC before but I may have some notes on it somewere. I use Dostek DNC and Enet DNC software and like them both. These are not free software as you are looking for but if you choose down the road you would like something with more bells and wistles let me know I will give you the contact info. Also I know Dan Fritz has his own software. I don't think it's free but I believe he has trial versions. As for free software I copied this link from another thread that Al posted as free software. I know there is more out there. Try google. If not you can always use your HyperTerminal which every PC should have. http://www.cadem.com/dnc/freednc.htm Stevo |
| why dont you pcmcıa compact flash card function.? it s very easy and good. you need cf card and pcmcıa adapter. and you useing dnc card between cnc. Tape or remote mod - program push-- oprt-- dnc-- and other.. very easy. The cnc is can read for CF card and runing, we using this method fanuc o i mate mb ,,
__________________ KİNG NOTHİNG Last edited by udrııl79; 07-30-2009 at 07:48 AM. |
How to use HyperTerminal method for transfering programs? Thanks for your kind help. The given link does not download the free DNC software. Sinha |
| I get the following message when I click the link to download the free NCnet Lite software. Any idea? The following URL could not be retrieved: ftp://ftp.cadem.com/pub/ncnet/ncnetlite70.exe Squid sent the following FTP command: CWD ncnet and then received this reply ncnet: No such file or directory |
| Sinha, For some reason I can't attach the document for setting up HyperTerminal. Send me a PM with your email address and I will send it off to you. Moderator, I was not able to attach the word document. It is only 280kb and we are allowed 500kb. It sat for about 1.5min trying to upload then the Internet Explorer timed out. I tried several different documents and they worked. This tells me it is probably the document. Any ideas what it could be?? I copied and paste to a new document, and tried zipping the doc but no luck. Stevo |
#10
| In a manual supplied by the MTB, the method to prepare the null modem cable is given: 5---5 2---3 3---2 1---1 4---6 6---4 7---8 8---7 No connection for pin 9 is given, but I suppose, it is Frame Ground. So, 9--9 should be connected. Or, should there be no connection between 9---9? Please comment. |
| Mazak Program Transfer | Mark18969 | Mazak, Mitsubishi, Mazatrol | 14 | 11-09-2009 04:06 PM |
| NC Transfer Program | JamesBond | General CAM Discussion | 69 | 04-07-2009 06:40 PM |
| transfer of program | Dar | Bridgeport and Hardinge Mills | 10 | 09-13-2007 09:43 PM |
| program transfer problems | johnd | Mach Mill | 5 | 12-24-2005 03:27 PM |
| Program transfer software?? | MattMachinist | General CNC (Mill and Lathe) Control Software (NC) | 3 | 07-22-2005 02:05 PM |
