Old 07-27-2009, 11:46 AM
Pyretta-Blaze is on a distinguished road
Data transfer software for Fanuc 18-T
Hi.
I have a problem with my lathe that has Fanuc 18-T control. The problem is that I have to have a computer for tranfering programs to lathe's memory and back, and now my computer is broken.. I had a very, very old computer with no graphic operating system, just dos-based software for data transfer and simple editing, and the programs were stored simply as xxxx.min files. I once opened one file with notepad and it only contained the code, nothing else.
Now that my computer is broken, I have to have some kind of software through which I can do the transfer, can anyone tell me what kind of program should I get, possibly running on a bit newer computer and a graphic OS such as Win XP or older? Or even Linux, though I don't know how to use it. Any free and easy software, I have no idea what should I get or where to find it. It doesn't even need to be a kind of software that has editing state, just one that does the transferring to lathes memory and back.
Thanks...
Old 07-27-2009, 11:57 AM
Al_The_Man's Avatar
Free one here for one machine. http://www.cadem.com/dnc/freednc.htm
Old 07-27-2009, 03:59 PM
DMF_TomB is on a distinguished road
you might try Hyperterminal which is included with Windows XP.
Old 07-27-2009, 11:34 PM
fanucman is on a distinguished road
that is correct i use it all the time.. .and its free!
Old 07-28-2009, 11:41 AM
Ok thanks very much, i didn't realize I could use even hyperterminal for that...
But another problem, does anyone know what kind of com-port connection settings do I have to use for that fanuc control? Baud rate, stop bits etc? I haven't done the earlier computer installation myself so i don't know what should be used. I have a few manuals for that lathe but the connection settings are mentioned nowhere...
Old 07-28-2009, 11:25 PM
just do this
make parameter 12 bit 0=1
553=11 for 9600 or 10 for 4800
make ISO =1
make i/o=1
and you should be set..
Old 07-29-2009, 09:56 AM
Originally Posted by fanucman View Post
just do this
make ISO =1
make i/o=1
Could you explain these settings, im not an expert with these things...
Old 07-29-2009, 12:59 PM
if you go into the parameter setting page...
you need to set those parameters just like i showed..
make PWE=1 and do those changes...
acutally these are for the zero systems... so i fawked up sorry...
ill post them when i find my book...
Old 07-29-2009, 01:15 PM
macrosat is on a distinguished road
dnc
try dostek dnc.
Old 08-07-2009, 05:30 AM
Any news about the settings yet? I'd appreciate if someone could explain what parameters should i change, and also to what should the connection settings be set to.
Old 08-07-2009, 08:37 AM
Al_The_Man's Avatar
This is for the Cadem s/w for the 18m.
  #12   Ban this user!
Old 10-19-2009, 12:36 AM
BTW I got the data transfer thingy working, downloaded cadem free software and with Al's help the settings are now as they should. Also tried hyperterminal and it works also, but its a bit difficult for me to use because the little experience I've got from it comes from years ago at secondary school.
Thanks Al, you're the man.
Tags
fanuc 18t software
Need Help!- Portable CNC data transfer Box xyzer Machine Problems, Solutions , Wireless DNC, serial port 1 07-21-2011 12:53 AM
FANUC O-TD data transfer problem flyfishing89 Fanuc 6 06-04-2009 04:44 PM
Newbie- Problem with Data flow between Fanuc 6M and DNC software Saluce Fanuc 1 08-27-2008 07:20 PM
Recommend data transfer software for Fanuc Series 21i-TB dazz_ Fanuc 13 05-02-2008 12:47 PM
Fanuc 9M data transfer problem YOO Fanuc 1 01-18-2007 08:26 AM
