Old 07-21-2009, 06:35 PM
botts_ is on a distinguished road
Error 416 X-Axis Disconnect
We are having issues with one of our older O-MC controllers. I will outline the history of the problems and the actions that have been taken so far.
The controller is using three axis X,Y and Z. Currently the X-axis is giving us a 416 X-Axis Disconnect.
Since we have four (4) similar machines I am able to interchange parts to try to isolate the problem.
Currently I have interchanged the following items one at a time to try to eliminate the problem.
1) X-Motor
2) Cable from Motor Encoder to Axis Board (Servo Feedback Cable)
3) Cable from Axis Board to Servo Amplifier.
4) Servo Amplifier
5) A16B-2200-0360/04B 1/4 axis board.
6) A16B 1211-0901/12 B PMC-M board.
7) All parameters have been verified with adjacent machine.
On occasion I have been able to get the controller to power up, but as soon as there is a certain vibration it will go into X-Axis Disconnect or if I disconnect the encoder cable and re-seat it I will sometimes get it work momentarily. I would like to know what actually causes the X-Axis Disconnect? and what else can I check/replace.
Thanx in advance
Old 07-21-2009, 08:30 PM
avtechmachine is on a distinguished road
Have you try to disconnect servo motor to ballscrew and power up machine just run the motor only??
Ahn Vuong
Old 07-22-2009, 06:05 AM
yes i have even tried a spare motor sitting on the floor.
I am at a loss as to why this is happpening and hope that someone knows what generates this error.
Old 07-22-2009, 02:02 PM
GPena is on a distinguished road
There is a chance that the base at the mother board is bad(cold weld), try changing the whole controller: mohter board, memory, etc.
Old 07-24-2009, 01:54 PM
fanucman is on a distinguished road
does the machine have a scale on x axis?
Need Help!- Error 414 Z-axis error detect servo alarm andywids General Metal Working Machines 1 07-09-2009 09:56 AM
Problem- 4th Axis Disconnect on 0M Control billgiles2 Fanuc 4 02-22-2009 07:57 PM
y axis disconnect alarm kirby Fanuc 8 03-14-2008 04:27 PM
5 AXIS POSTPROCESSOR "DISCONNECT" PLASTICMAN Post Processor Files 5 05-05-2006 12:52 PM
Fanuc 21-GA_416 Alarm-Axis Disconnect lasermike Machine Problems, Solutions , Wireless DNC, serial port 0 03-10-2005 12:49 AM
