Old 07-16-2009, 01:53 PM
coot is on a distinguished road
ALARM: SR821 - CD Off (1)
I've searched the various threads and it appears that the 6-8-20 jumper on the FANUC side is the key to this error, but we're getting it very sporadically. Checked the cable and everything seems good. Could there be something internal at the control that might cause this? This is on a 15MEA-B-4.
coot
Old 07-16-2009, 03:37 PM
Al_The_Man's Avatar
DCD usually refers to pin 8.
If you have 6-8-20 jumpered it usually takes care of it.
Make sure not connections are made between controller and PC on these lines, also do you have 4-5 jumpered?
It is possible the port can be defective on the CD input.
Old 07-16-2009, 05:47 PM
dcoupar's Avatar
Check your parameter manual (if you can find it). Mine is for the 15MEL-B-4, but it may be the same for yours.
Parameter 5000 bit 4 = 1 doesn't check the CD signal. Might just fix your problem.
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) PICMAN Fanuc 9 03-27-2011 06:14 PM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm doubleeagle Daewoo/Doosan 4 06-12-2009 03:15 PM
Problem- Alarm 350, not in my alarm list, any ideas? ralph@nes Mazak, Mitsubishi, Mazatrol 4 09-27-2008 01:14 PM
