Old 07-14-2009, 07:35 AM
visu is on a distinguished road
Reference point shifting in a VMC
A vertical machining centre is equipped with a Fanuc 0M-C control. Whenever the machine is switched off and then on, the reference point is shifting in X and Y axes by variable amount (The shifting is not consistent each time the off and on cycle is repeated). The screws of the limit switch banks and the actuators (of X and Y axes) are tightened but there is no change. Please advise on the next course of action
Visu
Old 07-14-2009, 12:11 PM
avtechmachine is on a distinguished road
I do think you should look into the X & Y deceleration switch, or replace it, it sound like the switch is not repeating
Ahn Vuong
Need Help!- Fanuc21i-T - Reference point problem Dare Fanuc 6 01-22-2009 04:04 PM
Problem- G30(reference point return) Reg wharton Daewoo/Doosan 2 06-13-2008 05:32 AM
Shifting the curved end toward one side randyf1965 SheetCam 2 04-26-2006 06:51 PM
Return through reference point? RBrandes Haas Mills 3 12-02-2005 09:49 AM
Shifting rod venomx999 Mechanical Calculations/Engineering Design 2 11-30-2005 11:07 AM
