Old 07-09-2009, 10:32 AM
gabedrummin is on a distinguished road
Elox / Fanuc Flushing pump
My machine used a Grundfos cr2-130 pump that is now obsolete.....The pump is run by the inverter unit.......Has anyone had to replace the tall multi stage flushing pump...? What have you replaced it with ? What are the motor specs.?....thanks to all............!
Old 07-13-2009, 07:22 AM
duccnc is on a distinguished road
System Error 998
Hi gabedrummin,
I have a OMA Elox wirecut machine.It's a good machine but.. now on the screen has display "SYSTEM ERROR 998 "and ... nothing happen .I know I have to burn new EEproms to fix it but ... I don't have any backup files of these EEproms.Can you or any one on the forum send me the EEprom files of the machine to help fixing my wirecut machine? I would be greatly appreciated your help
Thank you in advance
duccnc
My E mail: duccnc2007@yahoo.com
Old 07-13-2009, 02:10 PM
I have a problem with taper cutting and need to see the list of parameters from your machine....not the ones from the book///but whats in the machine dont know if my problem is bad pars or something else....I could get a eprom copier from ebay for 60.00 dollars.....I need to see par list first to make sure everything is working first...... Before I make copies of my eproms....I have a spare main board that is rev 16b........
Old 07-14-2009, 06:41 AM
My machine has 998 system error (parity rom) so I cannot read the parameter from the machine by RS232.I can send you the parameter list attached with my machine, if you still need it.I have checked it with the one on the machine before,they are indentical.What 's your problem with taper cutting? I can help you,usually the problem with taper cutting comes from the declaration on the screen of taper cutting ,not from parameters
Old 07-14-2009, 09:21 AM
It says taper data setting error.......I am using a setting of 1 for taper cutting I have the guides data entered........alarm...40
Old 07-16-2009, 06:36 PM
jdeere4250 is on a distinguished road
for the 998 rom alm, please reseat the rom chips.
if that fails look at the number that is common to all the chips ie 0465 or what everthen take the alphabeth number after the location num. ie FCIB where the Bis rev num. Then call fanuc america 888-326-8287 they will burn you a new set reasonable.
Old 01-13-2010, 10:15 PM
DougWoz is on a distinguished road
Fanuc can only write chips that are viable (and only in Chicago). 988 error means that the ladder program is corrupt. I have the same problem on a Bridgeport Fanuc OM control and I have to go back to the company that bought them out, so Elox would have had that information not Fanuc (I have had them out to my shop and I know that for sure). On the older Fanuc Machines the Ladder program will not displayed on the screen.
To gabedrummin have not heard from you since we got our Elox running. our actual feed rate for a 1 1/2 piece of steel is .089 inches per minute and .25 inches per minute on a finish skim cut. That's 3 times faster than when we started.
Old 01-14-2010, 06:32 PM
sounds like you are making progress on your feed . keep in mind that these machies were only rated at 6.00 inches an hour.....that cutting in a one inch tall block . The taller the block the slower it will cut . You need to make sure your power feed wires are in good shape , and good ground wires , corussion cut wires dirt bad contacts will slow it down .....What did you end up using for edm conditions ?
Old 01-16-2010, 09:01 PM
That may be true, and especially for a flusher 0.1 inches a minute. and that's with a new machine. But with the modification we made on the lower head, which keeps the lower head cover & saturated keeping the contact block always wet, (which by the way was 90% of the wire breakage). Increased our speed dramatically.
I have searched my laptop and can not find the Parameter list. I will have to search my Desk top for the file latter. Send email address to send file.
Old 01-17-2010, 10:53 PM
I have not replaced the pump on ours but we just gutted a series N Elox and there were 2 pumps on that. Those and the one on our series O use a 200v Pump. Have no Idea where to get one. Saving ours if we need in the future.
EDM FLUSHING PUMP gabedrummin EDM Machines 1 07-09-2009 04:10 PM
Need Help!- ELOX FANUC gabedrummin Fanuc 5 05-06-2009 08:16 PM
ELOX FANUC gabedrummin EDM Machines 0 03-16-2009 11:03 AM
elox fanuc w..wo...w1....w2.... gabedrummin EDM Machines 0 10-20-2008 05:01 PM
Problem: ELOX EDM with Fanuc 11M cahipun CNC Plasma and Waterjet Machines 1 09-25-2008 06:10 PM
