Old 07-07-2009, 11:49 AM
PICMAN's Avatar
PICMAN is on a distinguished road
750 ALARM SPINDLE-1 ALARM DETECT (AL11)
I HAVE HAD TWO TECHS LOOK AT THIS PROBLEM AND THEY DON'T SEEM TO KNOW WHY I AM GETTING THIS ALARM. ONE HAD ME PULL THE POWER SUPPLY TO HAVE IT CHECKED. P.S. WAS GOOD. ANOTHER TECH HAD ME PULL THE SPINDLE AMP AND IT WAS GOOD. WHERE CAN I GO FROM HERE. I APPRECIATE ANY INFO. ANYONE COULD PASS ALONG. FANUC 18-M CONTROL
THANKS,
PICMAN
"NEVER LOOK A BOUNTY HUNTER IN THE EYES"
Old 07-07-2009, 08:23 PM
jdeere4250 is on a distinguished road
what is part num of drive unit. A06B-xxxx-xxxx ?
Old 07-10-2009, 08:06 PM
rlabonte18 is on a distinguished road
Is there a prox sensor to orient the spindle. We get this alarm on our live tooling if the prox is out of adjustment when it orients.
Old 07-10-2009, 08:18 PM
hey, questions, what machine, model, drive num. display on drive unit?????
Old 07-13-2009, 01:50 AM
autronlee is on a distinguished road
this alarm is generated that the spindle amp is off when power on,if the machine have optic cable, please check the connection.or check in diagnostic 409 , is it SPE S1E SHE . Any one ofthis 3 have turn to bit 0.
Old 07-14-2009, 10:47 AM
PICMAN's Avatar
SORRY WAS ON VACATION
THIS PROBLEM SEEMS TO BE INTERMITTENT, THE ALARM DISPLAYED ON THE SPINDLE AMP IS 11. WHEN I TURN THE MACHINE OFF THEN BACK ON IT DISPLAYS A 20. THE MODEL #A06B-6102-H222 #H520 (SPINDLE AMP) THE MACHINE IS A LEADWELL MVC 1300 ER
Old 07-17-2009, 06:37 AM
I would check the incoming power. all 3 phases. as it now seems power related poss. put meter in record mode. also what cnc control is it?
Old 07-23-2009, 07:43 PM
mikkie is on a distinguished road
loose cables or wires will also cause it to drop out, either from the contactor that goes to the drive or in that line. also thier might be a 24v estop string that goes to the main PS that closes a switch to pick that contactor. i have no paperwork in front of me so i'm trying from memory
Old 07-24-2009, 01:48 PM
fanucman is on a distinguished road
its a DC over voltage alarm.. like this guys says.. check 3 phase power to power supply... aka phase to phase should be 200 vac
Old 03-27-2011, 06:14 PM
Sandro Martins is on a distinguished road
ola amigo
esta ocorrendo o alarm 07 na power supply? se OK o defeito esta na fonte e nao no spindle
obrigado.
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm doubleeagle Daewoo/Doosan 4 06-12-2009 03:15 PM
Help! alarm 414 X axis detect err CVMW Fanuc 8 01-10-2009 07:42 AM
434 servo alarm: Z axis detect error padobranac Fanuc 19 07-30-2007 03:12 PM
m32 alarm 27 magnetic position detect malf. barebonzchop Mazak, Mitsubishi, Mazatrol 2 11-02-2006 09:48 PM
