Old 07-06-2009, 02:11 PM
Toddxmann is on a distinguished road
YANG VMC1000 OM-D
Parameters were changed and I lost the tool change macro. How do I get the macro back in since I cannot type in any [ ] brackets and machine wont accept programs with [ ]?
Old 07-06-2009, 03:31 PM
sld4121 is on a distinguished road
Is Custom Macro B turned on in the machine or are you dealing with Custom Macro A?
Since you specifically call out a 0M-D, I am assuming it is not a 0I control. That control would have parameters to change from round to square brackets.
Old 07-06-2009, 04:54 PM
tool changer
this custom macro a ,b thing is all new to me. i dont have a clue how to turn on off or where its even at! i just want to make a ****ing tool change (curse you fanuc controller) why couldnt it just be a HAAS !
Old 07-06-2009, 05:04 PM
Al_The_Man's Avatar
Check to see if 913 bit #7 is set.
Old 07-06-2009, 05:16 PM
should #913 look like this 10000000 , because it looks like this now 01111011 like i said im a virgin at this fanuc stuff , HAAS please
Old 07-06-2009, 05:25 PM
Al_The_Man's Avatar
It looks to me that 913 has been changed to something odd ball, what or how were the parameters changed?.
If you had Macro B before the 913 MSB would be set as you show it.
Sorry, can't convert it to HAAS.
Old 07-06-2009, 05:30 PM
al can you call me 619-733-8769 todd
Old 07-07-2009, 10:02 AM
RODMAN is on a distinguished road
Todd
Here is the Tool Change Macro from our Yang VMC 1000 with an OM-D.
Our #913 parameter is 11110110.
Good Luck,
Y TL CHG Macro.txt
Rodman
Old 07-07-2009, 12:24 PM
avtechmachine is on a distinguished road
Hi Todd,
change parameter 10 bit 4 to zero then you can load the tool change macro back to control, after that you should change 10 bit 4 back to 1 for just in case operator accidently delete the program
Ahn Vuong
714-938-1388
Old 07-07-2009, 08:05 PM
Todd,
This is only for your machine.
Parameter 932 = 10101001
Parameter 913 = 11110110
after that you can upload the tool change macro it should work
Ahn Vuong
  #11   Ban this user!
Old 07-14-2009, 06:34 PM
avtechmachine
Ahn Vuong , thanks for all your help everything worked well , now my tool change program isnt working properly . after tool carosel comes out , machine dosent go to G28 Z0. , It just sits there !!!!! Im pretty much gonna take out the .50 caliber machine gun and fix this thing once & for-all !!!!
  #12   Ban this user!
Old 07-14-2009, 06:51 PM
After tool carosel comes out and it stop, list of DGN need to check
X0017 bit 1 = 0 Carosel home position
X0017 bit 0 = 1 Carosel out position
X0020 bit 3 = 1 ATC position
X0016 bit 3 = 1 Spindle tool unclamp
X0016 bit 2 = 0 Spindle tool clamp
X0017 bit 3 = 1 Carosel pin down position
X0017 bit 2 = 0 Carosel pin up position
Ahn Vuong
Tags
fanuc, macro, tool change, yang
Annn Yang Machinery Co CNC Lathe LT1TRUCK CNC Machining Centers 5 03-29-2011 06:41 AM
Problem- YANG VMC1000 OM-D ALARM 1007 Toddxmann Fanuc 3 04-23-2009 05:12 PM
Need Help!- Yang ML-25A Billet Sean General Metal Working Machines 1 04-22-2009 03:48 PM
yang growl BAD DOG Machine Problems, Solutions , Wireless DNC, serial port 1 02-16-2007 02:11 PM
