Old 07-03-2009, 03:51 PM
Josue is on a distinguished road
Fanuc 4M E44 hdlc response time-out error
Hello!
We're having a problem with a Amada Vela Turret Punch Press, this morning after blowing compressed air on the inside of the control cabinet of the machine's FANUC 4M control, the operator couldn't make it work, it was fine before that.
We are getting a message: "E44 HDLC response time-out error"
We think it must be a loose component but we couldn't find it.
Any clues?
Thanks in advance guys!
(I was hoping Al_The_Man could see this post).
Old 07-04-2009, 07:30 PM
Dan Fritz is on a distinguished road
I don't believe that Fanuc ever made a 4M control. The number 4 is very unlucky in Japan, so they made a system 0, a system 3, a system 5, a system 6, 7, 9, 10, 11, 12, 15, 16i, 18i, and 21i. Never a 4 or 13 or 17 as far as I can tell.
Please post photos of the operator's panel and internal boards if you can.
Old 07-06-2009, 08:09 PM
jdeere4250 is on a distinguished road
The cnc is a 04PC, this an amada thing. i hate it when builders get this cock-a mamie stooopid fooolish idea. Call the darned thing by its proper name. Itis a 0PC control. best I can tell this is an amada side alarm. There is a amada software and sequencer on this machine tool.
Old 07-07-2009, 08:06 AM
Hello Guys. Thank you both for your posts.
Dan, I haven't been able to get the pictures and it seems jdeere4250 is right the model on the name plate is 04PC. The maintenance guys found a loose cable near the screen, they pluged it back in some LEDs turn on but the display goes off. They also mentined that the batteries and their holder is very clean as if someone had removed they recently so I was thinking the problem might be a firmware thing.
What do you think?
Old 07-07-2009, 08:04 PM
Ok Boys, the best I can do is this, I have notes from my distant past on 04pc. This Amada CNC has this PHNC thingy which is the amada side. It does have Firmware or Amada software. As far as I can remember it resides on a fanuc pcb known as fanuc mmc which is an interface between the machine tool and the control. The notes I have is partly in japanese and also eng seems to indicate a misscomunication error between the 04pc and the PHNC part of the machine . I will see if I can get some help from my Amada friends and or Jap friends.
Old 07-08-2009, 08:25 AM
Thanks jdeere4250, I appreciate it.
Josue.
Pura Vida!
Old 07-08-2009, 01:29 PM
BodylinezCNC's Avatar
BodylinezCNC is on a distinguished road
Is the interface MMC or MMI?
I always thought it was Man Machine Interface(MMI).
Thanks,
Brent
Old 07-21-2009, 11:07 AM
Hi Guys!
I've been out, so I couldn't post.
I suggested the owner to call Amada Service, let's see what comes out of this.
Thank you all.
If you have any more input I will be greatly appreciated.
Josue.
Pura Vida!
TC4 error - auxfuncs: spindle time-out emvali Bridgeport and Hardinge Mills 7 03-03-2009 11:45 AM
okuma 2008 error. DMA transfer does not complete within a specified cycle time. mikul General CNC (Mill and Lathe) Control Software (NC) 0 05-28-2007 11:36 AM
Fanuc O-md Lube Time Alarm!!!! sco999 Fanuc 5 04-28-2007 10:14 PM
Fanuc 15MA Time utengineer04 Fanuc 2 06-09-2005 02:14 PM
Run Time Error Line Mr.Chips Forum Questions or Problems 2 02-03-2005 09:57 PM
