Old 06-29-2009, 04:19 PM
JimBoyce is on a distinguished road
Fanuc 10M, EMG Display On, EMG Button OK, Rev 6-29
Thank You GUHL
We checked the EMG button and the relay it actuates. They are OK.
We looked at the ladder diagram on he machine, but frankly it is way beyond our capabilities in that area, but we would like to know the logic flow that allows the control to come alive.
The emergency button actuates a Relay, CR17, this is OK.
A new relay did not help.
This problem occurred after a total reload of all parameters by a qualified person who has sucessfully done this before.
The machine appears OK except the EMG display on the bottom of the CRT stays on and the machine is dead.
We are leaning toward some parameter that keeps the EMG on, but what one? Thanks.
Old 06-30-2009, 02:03 AM
guhl's Avatar
guhl is on a distinguished road
Originally Posted by JimBoyce View Post
Thank You GUHL
Check option relays. The option relays - are the software links in ladder. May be one wasn't set up. They are marked "OPx.x". The first "x" - number of byte, the second "x" - number of bit. Try to find one in EMG line of ladder. To set up push "NC/PC" -> software key "relay" (or "option relay" - don't remember exactly). Then set the proper bit in byte.
Soviet ICs are the largest ICs in the world!!! )))
Old 02-24-2011, 01:22 PM
dand0321 is on a distinguished road
Thank You GUHL
mine did the same thing. PARAMETERS!!! i'm telling you check them or edit them.
Fanuc O-MD prog ck display yoshi900 Fanuc 3 10-15-2008 05:35 AM
Fanuc Oi-TC Control, can't use measure button?? Darc Fanuc 13 02-18-2007 11:09 PM
Fanuc OT control Auto Button thardy Fanuc 3 11-12-2006 09:52 AM
Position Display on fanuc 6m fredf1 Fanuc 1 10-22-2005 04:08 AM
