Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: Parameters, I think
    Jan 2006
    Parameters, I think
    I just started running a supermax with an 0t controller, when I first used it, it did not recoginze any tool offsets, I spoke with fanuc and they told me which parameters to set, now I get my tool offsets, but after any tool change, it seems to take off the wrong direction.
    I notice when I am in single block, I can watch the position numbers change, as I am being very sure sending the machine home every tool and reseting zero with g50 to zero, then using a g50 with a "w" to offset for the distance from the face of the chuck (where my tools are set) and zero on my workpiece. After any tool change, I can watch the numbers reset, then when it calls up the tool, the offsets input do not relect anything to do with the tool offset, not even compounding offsets, HOWEVER, if I simply hit reset and run the next tool by an "N" search, it runs perfectly!?!
    Has anyone seen this before?
    Jun 2008
    Are you canceling your previous offsets before the tool change? T00?
    Stevo
    May 2007
    Do you have to use G50?
    Registered dcoupar's Avatar
    Mar 2003
    Please post your program here.
    Jan 2006
    I am ending the previous sequence with g28 u0w0;
    example:
    N1
    GOG28U0W0
    G50X0Z0
    T0101
    G50W-4.5
    G50S2000
    GOX3.Z1.G96S500M3
    Z.1M8
    GOZ1.M9
    G28U0W0
    M1
    N2
    G0G28U0W0
    G50X0Z0
    T202
    G50W-4.5
    G50S2000
    G0X3.Z1. etc
    I cannot use T0, it wigs out the machine making it bounce between tool 8 and tool 1 (8 station turret) I then have to power down the machine to get it to stop.
    I have tried using T0100 to cancel, but it did nothing. I think there may be a parameter setting to recognize this command.
    As I run this through single block on program check, I can see my ABS numbers reset at G50X0Z0, Adjust my shift at G50W-4.5, then when the tool is called, it pulls up numbers that do not jive with anything, it is clearly not compounding tool offsets.
    However, if I reset and search N2, N3, etc, it will run just fine.
    Jan 2006
    And thanks for any help you can give me!!!
    Mar 2003
    I've never seen G50 X0 Z0 in a program like that. In the "old" days, G50 Xnn.nnnn Znn.nnnn was used to set the distance from the tool tip (at home) to the part zero. Does your control have both GEOM and WEAR offsets? If so, what values do you have in the GEOM offsets for T01 and T02?
    Jan 2006
    the reasone I went to G50X0Z0 is because I could not cancel the tool offset and this seemed to do that.
    The tools are set to the chuck face and c/l, the G50Wxx.xxxx represents the distance from the face of the chuck to part zero.
    I am using Geometry offsets on the tools as well as wear, but none of the wear offsets are more than .004"
    Mar 2003
    What happens if you take the G50 X0 Z0 out of the program?
    Jan 2006
    it compounds the offsets with the new and previous tlo
    Jun 2008
    Heavy....I assume that you have the machine setup to use 4 digits for the tool offset. When you try to cancel the tool offset do you program a T0100 or T0? I do not know why you would not be able to cancel your tool offsets.
    Dcoupar.....For the Ot control is there a parameter that specifies to clear offsets with the G28? IIRC I have set before on one of our lathes but it was not a Ot control. If there was a parameter for this and it was set then the G28 should take care of clearing the offsets and the G50 can be removed. Are you thinking the problem exists with the G50?
    Heavy..... you say that if you remove the G50 the tool offsets double correct? What if you were to take your tool offset and cut it in half then remove the G50...will the machine go were it is suppose to. If it does the problem remains with the G50 and we would have to figure out how to get your offset canceled without the machine going all funny.
    Stevo
    Registered chucker's Avatar
    Nov 2007
    You have said that all of your tools were measured off your chuck and that the W was the distance from the chuck to the face of the part the W move will not change the geometry offsets the tool thinks that the part zero is the face of the chuck sounds like you need to set a work shift or work offset (G54) to move your part zero to the face of the part and I agree you need to take out the G50 if the tool still moves the wrong way you mite try changing the value of your geometry offsets from plus to minus or the other way around also I would check to see if there is a vaule in your work shift if you have one.
  • Page 1 of 2 12 LastLast
    1. Oma parameters to pc
      By monaro mike in forum Fanuc
      Last Post: 06-08-2009, 06:43 PM
    2. Need Help!- Need parameters for SMG
      By RRL in forum Fanuc
      Last Post: 03-25-2009, 02:02 PM
    3. Cannot see my 900 parameters in my 0M-C
      By elvicash in forum Fanuc
      Last Post: 02-24-2009, 08:44 PM
    4. Need Help!- oma parameters
      Last Post: 07-03-2008, 06:28 AM
    5. G83/G87 parameters
      By DocHod in forum Fanuc
      Last Post: 11-04-2007, 02:54 PM
