Old 06-23-2009, 12:10 AM
gbowne1 is on a distinguished road
FANUC 0M Servo Amplifiers
I have a FANUC 0M-B
Does anyone know the differences of these 0M Servo Amps?
They are A06B-6058-H003
A06B-6058-H004
A06B-6058-H005
A06B-6058-H006
Are these the right ones for the 0M?
Greg Bowne
Old 06-23-2009, 02:00 PM
guhl's Avatar
guhl is on a distinguished road
I know about spindle servo units only. May be i will help you
A06B-6052-H001 -> MODEL 1; external radiation type; 8000 rpm
A06B-6052-H002 -> MODEL 2; external radiation type; 8000 rpm
A06B-6052-H003 -> MODEL 3 (small type); external radiation type; 6000 rpm
A06B-6044-H103 -> MODEL 3; internal ventilation type
A06B-6044-H203 -> MODEL 3; external radiation type
A06B-6044-H106 -> MODEL 6; internal ventilation type
A06B-6044-H206 -> MODEL 6; external radiation type
A06B-6044-H108 -> MODEL 8; internal ventilation type
A06B-6044-H208 -> MODEL 8; external radiation type;
A06B-6044-H308 -> MODEL 8; internal ventilation type; 6000 rpm
A06B-6044-H408 -> MODEL 8; external radiation type 6000 rpm
A06B-6044-H112 -> MODEL 12; internal ventilation type
A06B-6044-H212 -> MODEL 12; external radiation type;
A06B-6044-H312 -> MODEL 12; internal ventilation type; 6000 rpm
A06B-6044-H412 -> MODEL 12; external radiation type; 6000 rpm
A06B-6044-H011 -> MODEL 15; internal ventilation type
A06B-6044-H023 -> MODEL 15; external radiation type;
A06B-6044-H039 -> MODEL 15; internal ventilation type; 6000 rpm
A06B-6044-H050 -> MODEL 15; external radiation type; 6000 rpm
A06B-6044-H046 -> MODEL 18; internal ventilation type
A06B-6044-H047 -> MODEL 18; external radiation type;
A06B-6044-H048 -> MODEL 22; internal ventilation type
A06B-6044-H049 -> MODEL 22; external radiation type
A06B-6044-H130 -> MODEL 30; external radiation type;
A06B-6044-H140-> MODEL 40; external radiation type;
Soviet ICs are the largest ICs in the world!!! )))
Old 06-23-2009, 06:51 PM
I know about the spindle servo amps.. but not the ones for the axis servos.
I need the info on the part numbers I gave.
thanks for the information though.
Greg
Old 06-24-2009, 01:48 AM
f-bu is on a distinguished road
Asking Google:
http://fanuc.cnc-electronics.com/dri...8-h-servo.html
Old 06-25-2009, 02:18 AM
I also need to know which ones work on the 10M and 11M controls.
Is the servo amp for the 11M the A06B-6058-H004 or H005? Which top boards does it have? The top board should be a A20B-1003-xxxx or -xxx part number. I need to know before I go order one off of eBay.
The machine is a 4 axis. 4th is my Rotab on my 11M controlled machine. The 11M has AC servos.. Red Cap.
My 10M machine has DC motors Yellow Cap.. same 4 Axis set up. It's a smaller machine than my 11M though. Are all the 10M servos yellow cap? I believe they are either A06B-6051-Bxxx or A06B-6041-Bxxx part numbers.
Thanks.
Old 06-27-2009, 07:12 AM
guhl's Avatar
My Tsugami NU4B with 10T control (I suppose no difference between 10T, 10M, 11M in this case) equiped with Yellow Cap motors 5M and 0M series. Two servoamplifires (for 2 axes each) with similar PCBs: A20B-1000-0220/06B - upper plate
A20B-1200-0230/05B - lower plate
Another Tsugami NU4Y (also 10T) equiped with Red Caps motors
two drives A06B-0512-B002 (model 5 motor)
one drive A06B-0513-B002 (model 0 motor)
one drive A06B-0512-B202 (model 10 motor with brake)
Old 06-27-2009, 10:55 AM
yours_prabhat is on a distinguished road
please feel free to communicate me for all fanuc problems queries and clarification in troubleshooting and maintenance electrical and mechanical both
Regards
Prabhat mishra +91-9430737981
mail = prabhatmishra@mail.com
Need Help!- SLA7062M as PWM amplifiers? enok1969 General Electronics Discussion 1 06-22-2009 09:26 PM
Mesa 7i33 and AMC amplifiers Monroe Design LinuxCNC (formerly EMC2) 2 04-12-2009 10:09 AM
Servo Amplifiers at 240V CalG General Electronics Discussion 0 03-26-2009 09:35 PM
Trying to identify some servo amplifiers wpy Bridgeport and Hardinge Mills 19 11-08-2007 05:48 PM
glentek amplifiers yeepman2 Fadal 1 12-01-2005 05:44 PM
