Hi there fellow enthusiasts, I have a problem with programming a circular tool path on the outside of a bar in the c-axis using cylindrical interpolation. I have a Fanuc 15 TF but my manual is Fanuc 15 B (it doesn't cover A types). The G code for cylindrical interpolation is G07.1 When I program the following, the Z axis movs but the C doesn't rotate. The lathe hasn't ever run the cylindrical interpolation successfully to my knowledge... O0002(CYLINDRICAL INTERPOL) G28U0.W0. M98P9000(C-AXIS ENGAGE) (3MM END MILL) T1313M3(DRIVEN TOOL 3MM MILL) G00G40G97G98S1800 G0C0.0Z10.0 X28 M1 G07.1C14000 G18Z10.0C0.0 G18G02Z20.0C10.0R10.0F50 G18G02Z10.0C0.0R10 G01X30 G07.1 C0 G17 G30U0.W0.M05 M41 M30 If I step through, the program runs to the G07.1 C14000 (the radius of the bar) and says illegal use of G code - it doesn't like the C parameter with it's radiaus in minimum units being input. If I run the program then it doesn't crap out it just doesn't move the C axis - only the Z. If I change the code to.. G07.1 C0 or remove C altogether then the program runs but the radius carved on the outside of the bar is a squashed semi-cirle. I think it thinks the radius of the bar is much bigger diameter and so calculated the rotation of the C axis to be a small rotation - certainly not 10mm on the circumference. Any ideas anyone? The manual is $400 - and to spend that and find out that the code isn't in there would be a real bummer. Many thanks, John |
| Thanks dcoupar, I tried that but no change - it still rotates C short by a few degrees. I think it must be in the G07.1 parameters. It doesn't seem to recognise / do anything with the C parameter on the G07.1 line of code. If I insert a value then C won't rotate - if I put in zero or leave it out it rotates! |
| Just wondering I think there should be an R on the 1st line under the G07.1 I have never done this just looks like it should have an R there also you may need your feed rate moved up to the G07.1 line G07.1C14000 G18Z10.0C0.0 (R ?) G18G02Z20.0C10.0R10.0F50 G18G02Z10.0C0.0R10 G01X30 G07.1 C0 G17 G30U0.W0.M05 Last edited by chucker; 06-22-2009 at 08:42 AM. Reason: more info |
| Thanks dcoupar, sorry for the delay - I havn't checked my posts. Unlucky for me it looks as if it's more of a serious problem - I had a Fanuc engineer in and he thinks because the error message is 'Invalid use of G code' that it doesn't understand the C parameter. This is possibly because either a parameter hasn't been set or the eprom hasn't the cylindrical interpolation function installed (in the firmware). Only about £2k to get it installed - I'll have to work around as this is too much for me and I have no chance of finding what parameter needs setting to enable the cylindrical interpolation - we tried. I'm going to try Z/C circular interpolation and see if I can get it to describe a radius on the surface. |
| Newbie- Circular Interpolation | Deadwood | Mach Software (ArtSoft software) | 3 | 01-11-2009 02:35 PM |
| nx5 how to turn off circular interpolation | boofa | General CAM Discussion | 5 | 05-27-2008 02:03 PM |
| circular interpolation | sqatch | Dolphin CADCAM | 9 | 02-11-2008 12:02 AM |
| Circular or Helical Interpolation? | meme | General Metalwork Discussion | 6 | 10-30-2007 03:05 AM |
| question about circular interpolation | warpedmephisto | Benchtop Machines | 13 | 03-22-2006 04:51 PM |
