Old 06-16-2009, 09:55 AM
KBLANKE is on a distinguished road
G54.2 Dynamic Fixture offset funtion (30i)
I am looking for a sample program of the Dynamic fixture offset command. The machine is a NH8000 DCG Mori Seiki. I am not sure on the actual value to put in the offset table.
Old 06-17-2009, 08:22 PM
psychomill is on a distinguished road
The value is the "shift" value of part origin from the machine offset origin. Think of it as somewhat similar to G92/G52 except on a rotary axis. So, after you set a work offset to your center of rotation, you set the shift amount of how far your part sits "off center" of rotation. If you part sits at .003 to the left of center and everything else is on "zero", you would have a "-.003" in your X axis of dynamic comp...
As far as the command of using it, you only need have the offset show up like a standard work offset.
It's just a part..... cutter still goes round and round....
G54.2 DYNAMIC FIXTURE OFFSET KBLANKE Mori Mills 0 06-16-2009 09:40 AM
how do you use the fixture offset funtion cob Mastercam 7 11-18-2008 11:48 PM
Creating a Fixture Offset robmints Mastercam 18 08-31-2008 11:20 PM
NX5 Fixture Offset H234 General CAM Discussion 5 03-27-2008 08:12 AM
WTH Corrupt fixture Offset!? DareBee Fadal 3 07-15-2005 09:11 AM
