Old 06-16-2009, 06:45 AM
davidw731 is on a distinguished road
Need macro help
I have this macro for deep hole drilling on a lathe with fanuc control, it works great but it only works drilling in the Z minus direction. I would like to modify it to drill in the Z positive direction so that I can use it to drill on my sub spindle. I don't have a clue how to do it.
O9136(DEEP DRILL)
IF[#6GE0]GOTO70
G00W0.
#4=#5002
#3=ABS[#3]
#2=ABS[#2]
IF[#19EQ98]GOTO1
#19=99
N1G#19F#9
#27=ABS[#23]
#28=ABS[#6]-ABS[#26]
#29=ABS[#26]
DO1
IF[#27LE#3]GOTO2
GOTO3
N2#27=#3
N3IF[#27GE#28]GOTO4
G00Z-[#29-#2]
G1Z-[#29+#27]
G00Z#4
G4U#1
#28=#28-#27
#29=#29+#27
#27=#27*.5
END1
N4G00Z[#2-#29]
G1Z#6F#9
G00Z#4
GOTO99
N70#3000=1(K MUST BE NEGITIVE)
N99M99
Any help would be appreciated
Old 06-18-2009, 02:07 PM
bdyenter is on a distinguished road
Smile
Try This..... I only changed a couple of things and simulated on NCplot but
it looks as if it will work for you..
:1234
T101M8
G97S500M3
G0X0.Z-.1
G65P9003X0.Z0.K3.0B.05W.1C.35A.1F.005
G0Z-.5
M30
:9003
IF[#6LE0]GOTO70
G00W0.
#4=#5002
#3=ABS[#3]
#2=ABS[#2]
IF[#19EQ98]GOTO1
#19=99
N1G#19F#9
#27=ABS[#23]
#29=ABS[#26]
DO1
IF[#27LE#3]GOTO2
GOTO3
N2#27=#3
N3IF[#27GE#28]GOTO4
G00Z-[#2-#29]
G1Z[#29+#27]
G00Z#4
G4U#1
#28=#28-#27
#29=#29+#27
#27=#27*.5
END1
N4G00Z-[#2-#29]
G1Z#6F#9
G00Z#4
GOTON99
N70#3000=1(K MUST BE POSITIVE)
N99
M99
bRYAN
Old 06-18-2009, 07:34 PM
g-codeguy is on a distinguished road
That is the Hardinge deep drill cycle. I had thought to modify the program to drill in either direction, but haven't since it is almost never needed on the subspindle for the type of parts we run.
Bryan, why not add a block, modify one, and delete a few blocks?
:9003
G00W0.
#4=#5002
#6=ABS[#6]
#3=ABS[#3]
#2=ABS[#2]
IF[#19EQ98]GOTO1
#19=99
N1G#19F#9
#27=ABS[#23]
#28=#6-ABS[#26]
#29=ABS[#26]
DO1
IF[#27LE#3]GOTO2
GOTO3
N2#27=#3
N3IF[#27GE#28]GOTO4
G00Z[#2-#29]
G1Z[#29+#27]
G00Z#4
G4U#1
#28=#28-#27
#29=#29+#27
#27=#27*.5
END1
N4G00Z-[#2-#29]
G1Z#6F#9
G00Z#4
M99
Old 06-19-2009, 08:54 AM
Smile
G-Codeguy is right. It is much easier to just add another block and modify another one. It is easier to diagnose for future alterations, rather than changing signs to accomodate quickly.
ONE FIX FROM ABOVE...... I FORGOT A NEGATIVE SIGN IN THE BEGINNING OF THE LOOP. THE WAY IT WAS IT WOULD RAPID INTO POSITIVE .05 TO START DRILLING. NOW IT WILL START @ Z-.05 AND DRILL IN POSITIVE DIRECTION.
SEE CORRECTION BELOW:
:9003
G00W0.
#4=#5002
#6=ABS[#6]
#3=ABS[#3]
#2=ABS[#2]
IF[#19EQ98]GOTO1
#19=99
N1G#19F#9
#27=ABS[#23]
#28=#6-ABS[#26]
#29=ABS[#26]
DO1
IF[#27LE#3]GOTO2
GOTO3
N2#27=#3
N3IF[#27GE#28]GOTO4
G00Z-[#2-#29]
G1Z[#29+#27]
G00Z#4
G4U#1
#28=#28-#27
#29=#29+#27
#27=#27*.5
END1
N4G00Z-[#2-#29]
G1Z#6F#9
G00Z#4
M99
Last edited by bdyenter; 06-19-2009 at 09:31 AM. Reason: FORGOT NEGATIVE SIGN IN BEGINNING OF LOOP
Old 06-19-2009, 10:16 PM
Unhappy
thanks guys i'll try these monday
"difference between Custom Macro A and Custom Macro B" arulthambi Parametric Programing 4 10-05-2009 03:34 PM
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 03:15 PM
Macro A or B ? tonper G-Code Programing 6 03-20-2009 11:12 AM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-08-2007 11:41 PM
Macro omkargupta Fanuc 1 09-11-2007 02:35 PM
