Old 06-15-2009, 07:06 PM
jdgromi is on a distinguished road
Question Error 7156
Hello!
My lathe is a Romi M17 with a Fanuc 21i
When this error occure, 7156 SPN:1 inner cooling fan stop, a alarm goes on and my lathe stop.
I have three fans, one in the front door and two others on the right side of cabinet. The 2 fans on right side are stop. I have checked the voltage and I have read 0 volt AC and 610 ohms on each fan.
How can I repair this trouble? Where is the problem?
Best regards
Jean-Denis
Old 06-15-2009, 07:30 PM
avtechmachine is on a distinguished road
I am not sure how Romi run their electrical but normaly they have a no fuse breaker for the Fan and may be the breaker is trip, just need to reset?
Ahn Vuong
Old 06-16-2009, 01:25 PM
PMT PMT is offline
PMT is on a distinguished road
You will have fans inside your yellow spindle amp as well. I believe one inside the yellow box and anohter under the heatsink behind the main amp. the alarm on the amp should indicate which fan is out.
tl-2 program integrity error and program data error alarm #'s 212 250 need help CNChelp Haas Mills 12 03-14-2010 08:19 PM
Need Help!- Matsuura Mc500v seq error/magazine error mc500v General Metal Working Machines 10 01-08-2010 01:35 PM
Erreur 7156 jdgromi Français CNCzone 3 06-12-2009 03:12 PM
OM-A ROM PARITY ERROR "NOT RAM ERROR" offroadxx Fanuc 9 05-07-2008 08:15 PM
