| A M19 tool orientation will stop the spindle from moving. However this is not a “lock”. On some machines you can get the spindle rotating again by some force. I am not sure if that is what you were asking because you also said you need to get a highspeed spindle????? I am not sure what you are trying to do or what you mean by that???? Stevo |
| Uncle Buck, We do this on several machines with a high speed air attachement and jig grind a form. On an older Fanuc OM, we use M19. After the machine has oriented, we attach the air hose. On a newer machine with a fanuc OMD, M19 will not allow us to feed at the same time the spindle is oriented. Instead, we use use M3 S0. Then the spindle holds in one general position and we can feed with the air spindle around the form. We also have a macro to tweek the cutter comp each pass to move the tool in to the form. I can forward the programs and macros if this is the type of application you need. Robert |
| T32 Control Panel Lock up | bean79au | Mazak, Mitsubishi, Mazatrol | 0 | 07-13-2008 04:59 AM |
| Spindle Lock for SX3 | Old Megawatts | Syil Products | 1 | 05-01-2007 05:19 PM |
| lock programs with fanuc 16/18 control | Heavy D | General CNC (Mill and Lathe) Control Software (NC) | 3 | 03-30-2006 05:09 PM |
| m-code for spindle lock | fisholie | G-Code Programing | 6 | 12-17-2004 05:21 PM |
| spindle lock question | scott m | General Metalwork Discussion | 15 | 11-30-2004 07:18 PM |
