| The unit I have is about 12x4x4 This is part of the Fanuc spindle driver electronics. I read that it is used for braking but I don't know if all motors can use it or if its only a requirement for certain motors or if its used in combination with a motor and the drive. I am seeking to replace my Fanuc drive and expect I'll need this but for some reason finding clear information about motor systems has been difficult. Last edited by lavrgs; 06-06-2009 at 10:07 PM. Reason: add picture |
| It serves two purposes, assists in braking the motor for faster stopping and prevents bus over voltage by switching the regenerated voltage into a resistor bank when overvoltage occurs. Depending on what drive you are looking to integrate, most VFD's accept external braking as an option. Al.
| One of the things I am trying to do is determine a spindle drive that would be appropriate as a replacement. I don't want to "buy and try", I would like to have a high level of confidence that what I get will work before I get it. What I know Fanuc - model # A06B-1002-B600 #2000 200V AC 4 pole 3 HP 5 HP Peak 11 Amps 15 Amps peak 1800-8000 RPM There is an encoder on the motor The original control Fanuc a06b-6052-h002 |
| Need Help!- Regen overheat | engine tech art | Haas Lathes | 7 | 02-05-2009 09:31 PM |
| Haas spindel Deriver, Regen problem | tayfunk | Haas Mills | 14 | 09-01-2008 09:08 AM |
| Edgecam Bottleneck - ReGen TOO SLOW | 1ctoolfool | EdgeCam | 23 | 05-30-2007 11:58 PM |
| 2 month old Haas VF2D, Regen Overheat? | locash | Haas Mills | 10 | 02-16-2007 12:55 AM |
| regen toolpath kcam | oliver | General CNC (Mill and Lathe) Control Software (NC) | 0 | 07-16-2006 07:19 AM |
