Old 06-02-2009, 06:32 PM
LogicalFool is on a distinguished road
Fanuc 300iS-Model A B'Lash parameter 1851 and 1852 working for all axes but B axis
Fanuc 300iS-Model A B'Lash parameter 1851 and 1852 working for all axes but B axis. I put in a large value in both parameters. Do my backlash test after zero returning B-Axis and nothing changes. The parameters work fine for X, Y, Z, and A axes. The machine is a OKK KCV-1000 5-Axis.
Are there other parameters that enable or disable b'lash compensation per axis?
Thank You
201's, only two axes working bebson Gecko Drives 2 04-25-2008 05:28 PM
Does anyone have a Parameter Manual for Fanuc 21i Model A Eagle View General Metalwork Discussion 0 01-25-2008 03:52 PM
Fanuc 0M ATC Z axis parameter? mikul Fanuc 9 01-04-2007 03:16 AM
Fanuc Z axis not working Derek.C General CNC (Mill and Lathe) Control Software (NC) 5 12-05-2006 04:47 PM
How do I gang axes? X X Y Z not working. Javelin276 LinuxCNC (formerly EMC2) 4 03-06-2005 09:32 PM
