Old 05-25-2009, 09:07 PM
cha lee is on a distinguished road
Oops.., Fanuc AC spindle, A06B-6060-H008
Oooooops.. I believe the previous post incorrectly identified the drive.
Lets try this, Fanuc A06B-6060-H008.
We just picked up an old Harrison VS-450 CNC. The lathe sat around for a while but supposedly ran. Much of the documentation is missing but we seem to have gathered most of the parameters.
The latest bug to figure out is with the spindle drive. When trying to cycle a M03 or M04 the spindle doesn't move. The load meter rises and after a few seconds alarm #2 ( speed deviation )occurs on the Fanuc A20B-6060-H008.
If the spindle is turned by hand the alarm does not occur and the load meter reads 0. As soon as we stop hand turning the motor the load rises and the alarm times out again.
Interestingly if a low S code is used we can hand turn the motor/spindle fast enough to get the cycle to complete.( the cycle light goes out ) We can stop hand turning the spindle and no alarm occurs.
Strangely we can now cycle M 3,4, & 5 codes and the cycle completes altho the spindle intermittently jerks and give alarm 10. ( low incoming voltage? )
Resistance checks on the motor and wiring look OK. Checking the DC power supply shows about 340 vdc with little ripple. Altho I do want to replace the old capacitors they seem to check OK with a regular meter. Incoming voltage and wiring looks good. Outgoing voltage to the motor appears to be a few volts at most.
I invite suggestions. We have no spindle drive manual and wish I had schematics. Never having messed around with a VFD I also wonder how the load meter works on this system.
charlie
Old 06-05-2009, 09:23 PM
jdeere4250 is on a distinguished road
which control ?
how is it commanded. da1 ? or r01 to r12, analog or dig ?
sensor is maybe bad, alm2.
Old 06-06-2009, 10:43 AM
Control...?
Thanks for ur reply,
Control = Fanuc OTB. The 0 to 10vdc analog signal reads correctly as tested at VCD pin on the drive.
I suggest if the magnetic/hall effect senor is bad the alarm (#2/position deviation) would still occur when the spindle is turned by hand...This is not the case.
Old 06-10-2009, 08:28 PM
I saw something like this before on v. similar mach. It is possible that this motor has analog command. And that there is a spurios manual command along with the commanded speed fron the cnc hence the dev. alarm. Does it rotate correct in manual mode?. Now the speed sensor is most likely cause.
Need Help!- Fanuc VFD A20B-6060-H008 cha lee Fanuc 0 05-08-2009 09:59 AM
Maybe a big oops gadman58 Xylotex 3 06-27-2008 03:12 PM
Oops, and Oops Again. Geof Safety Zone 11 02-28-2008 05:31 PM
Fanuc A06B 6064 C312 Spindle drive jkford96 Fanuc 5 02-20-2007 09:16 PM
Fanuc ac A06B driver mariusborza Fanuc 5 10-26-2006 04:25 AM
