| Use Single Block with Dry Run. Take it slow and Read the Distance to Go on the position screen
| There is a parameter which sets rapid to 0 when feed is at 0. Look it up its 1401. You can set this so it crawls when rapid button is zero, BUT you must remember this because if you set the feed to 0, the rapid will keep crawling unless you hit feed hold. I changed ours so rapid 0 is 0. As others have said, dry run and watch the distance to go. And value for mony, get NC plot (off Scott on this site). This will boost confidence/prog proving. But no replacement for distance to go... |
| Rapid to (# set by Parameter) What's yours? | Scott_bob | G-Code Programing | 8 | 07-13-2009 07:05 AM |
| DOGLEG RAPID | cherokeechief79 | PTC Pro/Manufacture | 1 | 07-24-2008 11:16 AM |
| Need Help!- RAPID OVERRIDE | CNC_BOB | OKK | 5 | 06-02-2008 05:34 AM |
| rapid travel | iccirvr | Mach Mill | 8 | 05-19-2008 11:10 PM |
| Rapid moves G00 | dicksonhof | Mach Software (ArtSoft software) | 9 | 11-07-2006 09:21 AM |
