I need to see if anyone has a tool changer macro program for my Fanuc 0M-C for a Hamai MC-3VA. We accidentially cleared the memory and had to re-input everything but we don't have those programs anywhere. I believe they were program # 9000, 9001, 9002 or something like that. |
| I have a program that should work. You will probably have to do some tweeks to fit your machine. Another option is to call the MTB if they are still in business and ask them for the program or someone here might have the same model machine. There are a few ways that the position of the tool change could have been set. Machine home, machine home with a hard number programmed in the macro if the home is not the same as tool change position, or by using the G30 2nd,3rd,4th reference positions. The program below uses the machine home but if home and tool change position is not the same you will have to either adjust the Zposition in the program or use the other reference positions. This program is as basic and stripped down as you can get. There is generally a lot more to it that we can add if you want. I have all mine set up to track the current tool in the spindle, set the “G43H()”, set speeds and feeds, and bypass the tool change “M6” if doing a tool call of the current tool in the spindle. Now you will have to look at your parameters and see what macro program is being called with the M6 call. Then down load the macro program to the proper program number. On your control look at parameters 240-242. These call programs 9001-9003. If parameter 204=6 then program 9001 is being called as your tool change program. O9001(TOOL CHANGE PROGRAM) G40G80—(tool dia cancel & canned cycle cancel) G91G28Z0M9—(tool change position in Z & coolant off) M19--(tool orientation) G28Y0M5—(tool change position in Y & spindle stop) M6—(tool call of modal T value) M99 Stevo |
| Hi try a macro program an tel me..... O9001 G80G40 G65H81P25Q#1013R1 G65H81P25Q#1008R1 G65H01P#132Q#4014 G65H01P#131Q#4003 G65H01P#130Q#4006 M66G91G30Z0 G65H12P#1132Q#1132R4096 G65H11P#1132Q#1132R1024 G04P100 G65H12P#148Q#1032R255 G04P100 G65H12P#1132Q#1132R4096 G65H11P#1132Q#1132R2048 G04P100 G65H12P#531Q#1032R255 G04P100 G65H12P#1132Q#1132R4096 G65H01P#1115Q1 G04P100 G65H12P#149Q#1032R255 G65H81P20Q#531R#149 G65H81P1Q#148R#149 G04P100 M42 N1G65H81P5Q#1011R1 G65H80P1 N5G65H86P10Q#531R18 G#132 G#131 G#130 G65H99P1 N10G65H83P15Q#531R0 G#131 G#130 G65H99P2 N15G65H01P#1112Q1 G65H11P#1132R256 G04P100 G65H01P#1113Q1 G91G30Z0M19 M52 M12 G04P500 G28Z0 G65H01P#1114Q1 M41 G30Z0 M11 M53 G65H01P#1109Q1 G04P100 G65H12P#1132Q#1132R4096 N20G65H01P#530Q#531 G#132 G#131 G#130 N25M67 M99 % Ins-Tek |
| Testing program for Macro (Fanuc Macro B) | NickDP | Fanuc | 2 | 03-27-2009 03:15 PM |
| Wintec MV-45 with FANUC 18MC needs ATC Macro program | hrh | Fanuc | 4 | 01-12-2009 01:33 PM |
| G65 macro B PROGRAM | gollame | G-Code Programing | 2 | 05-11-2008 11:26 AM |
| Convert Fanuc Macro to Fadal Macro | bfoster59 | Fadal | 1 | 11-08-2007 11:41 PM |
| Macro program | pioneerproducts | Product Announcements & Manufacturer News | 4 | 10-08-2007 03:44 PM |
