Old 05-13-2009, 08:17 AM
guhl's Avatar
guhl is on a distinguished road
Cs axis control
What is Cs axis control?
Soviet ICs are the largest ICs in the world!!! )))
Old 05-13-2009, 08:52 AM
Al_The_Man's Avatar
On a lathe, C axis would be the spindle controlled as an Axis (C).
A third axis that revolves around the Z.
Old 05-13-2009, 11:20 AM
g-codeguy is on a distinguished road
Used to drill/tap holes from the side, and on the face for ones that aren't on the centerline. Can mill flats and other contours, engrave, etc. Holes drilled from the side must be in line with X-axis centerline. Need a Y-axis for holes that aren't.
EDIT: Uses what is known as "Live Tooling."
Old 05-13-2009, 11:26 AM
guhl's Avatar
What is difference between Cf and Cs axes.
Old 05-13-2009, 06:56 PM
Sorry. Can't help you there. First time I heard of either.
Old 05-14-2009, 05:48 AM
guhl's Avatar
I've found out.
Cf - C-axis is putted in action by separate motor via gears
Cs - C-axis is putted in action by spindle motor
single axis control? jayty97 Stepper Motors and Drives 1 04-08-2009 07:05 AM
Problem- 4th Axis Disconnect on 0M Control billgiles2 Fanuc 4 02-22-2009 07:57 PM
2.5 Axis Direction Control ee_cnc LinuxCNC (formerly EMC2) 2 11-21-2007 08:42 AM
y axis for spindle control ? jed102 DeskCNC Controller Board 1 09-10-2006 10:45 AM
How to control 8 axis? lepton TurboCNC 2 08-19-2006 09:35 PM
